JustGav Posted May 28, 2010 Share Posted May 28, 2010 heheheh, I thought so.... It does look smart must be honest. Quote Link to comment Share on other sites More sharing options...
jevansio Posted May 28, 2010 Author Share Posted May 28, 2010 Thinking out loud here and by no means even close to being a solution. Extending the racks pipework is easy enough, local hydralic place should be able to make the custom length pipes. Pump could be mounted somewhere on the chassis leg. Main wiring from high current feed to a high amp mosfet. Mostfet control can be via some sort of pulse to voltage convertor circuit run from the speed sensor. Right I've had a bit to drink, but are you saying that if you can get an electrically controlled pump to supply the exact same fluid as the belt driven one (rpm dependant) then the rest of the system should behave as normal? Quote Link to comment Share on other sites More sharing options...
JustGav Posted May 28, 2010 Share Posted May 28, 2010 Right I've had a bit to drink, but are you saying that if you can get an electrically controlled pump to supply the exact same fluid as the belt driven one (rpm dependant) then the rest of the system should behave as normal? That's my theory... (and I'm sober ) Quote Link to comment Share on other sites More sharing options...
JustGav Posted May 28, 2010 Share Posted May 28, 2010 Possible issue... I'm not sure if the electronic pumps are meant to be driven constantly, and if they aren't there would have to been some sort of column sensor that activates the pump when needed. Quote Link to comment Share on other sites More sharing options...
jevansio Posted May 28, 2010 Author Share Posted May 28, 2010 Dunno if you have to sign up for this but maybe worth a look http://www.twobrutal.co.uk/forum/showthread.php?11046-My-mk1-V8-(4.2-340bhp-Audi-AHC-with-6-speed)&p=219943&viewfull=1#post219943 Quote Link to comment Share on other sites More sharing options...
keron Posted May 29, 2010 Share Posted May 29, 2010 Have you removed the ac pump jay? that weighs loads more than the pas pump. and its useless in this country! Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted May 29, 2010 Share Posted May 29, 2010 The pump itself is very light, make alloy brackets if you must. Electric systems are not some sort of Flux Capacitor, they take battery power, a LOT of battery power. How is this regenerated? By ENGINE power through a high output alternator, so you gain no real performance advantage. It's like these damned Greens in electric cars, they never think where the power at the charging point comes from. You have a simple and reliable set up as stock, I would be loathe to alter it without very good reason. Quote Link to comment Share on other sites More sharing options...
hodge Posted May 29, 2010 Share Posted May 29, 2010 You like? http://i462.photobucket.com/albums/qq341/ghyslainleblanc/Speedsport%202010/IMG_7158copy.jpg heheheh, I thought so.... It does look smart must be honest. http://image.automotive.com/f/features/12715528+pheader/0902tr_11_z+1955_ford_f100+engine_bay.jpg They both look a bit cluttered to me;) Quote Link to comment Share on other sites More sharing options...
