transit belts
dr_jekyll
hello all.
i have just baught a 2000 2.0 transit . i dont know a great deal about the vans as i have never worked on comercial vehichles.
while looking over the van i noticed the power steering belt and altinator belt are a bit "tired" and could do with changing.
could anybody give me a likg to a guide on how to do these jobs or give me any tips.
the altinator belt has me a bit stumped as it has no tensioner to slak it off and it real tight .
all help will be apriciated.
Pm me your reg and i will do a guide to fit for you.
this might be it though....
Release Tool, Belt Tensioner
303-676
Removal
All vehicles
Disconnect the battery ground cable.
For additional information, refer to: Battery Disconnect and Connect (414-01 Battery, Mounting and Cables, General Procedures).
Raise and support the vehicle.
For additional information, refer to: Lifting (100-02 Jacking and Lifting, Description and Operation).
Remove the crankshaft pulley splash shield.
Using the special tool, detach the accessory drive belt from the accessory drive belt tensioner pulley.
Right-hand drive vehicles
Remove the steering column flexible coupling lower pinch bolt.
Discard the bolt.
Right-hand drive vehicles built 01/2000 onwards
Release the circlip.
Disconnect the steering column flexible coupling from the steering gear pinion.
All vehicles
Disconnect the generator electrical connectors.
Remove the generator.
Remove the generator support bracket retaining bolts and position the generator support bracket and the accessory drive belt tensioner assembly to one side.
Remove the accessory drive belt.
Installation
All vehicles
Install the accessory drive belt.
Install the generator support bracket retaining bolts.
Install the generator.
Tighten the bolts in the sequence shown.
Connect the generator electrical connectors.
WARNING: Install a new steering column flexible coupling lower pinch bolt. Failure to follow this instruction may result in personal injury.
NOTE: Make sure that the wheel hubs are in the straight ahead position.
NOTE: Make sure that the circlip is correctly seated.
Connect the steering column flexible coupling to the steering gear pinion.
Right-hand drive vehicles built up to 12/1999
All vehicles
Install the crankshaft pulley splash shield.
Lower the vehicle.
Connect the battery ground cable.
Edited by movistar (see edit history)
