After take off burning oil
TT Paul
start from the top, run'n 650cc injectors in ttc with emu and fully bpu..
has base map heres the history, old eng had low compression on 5 6, head wasn,t to good on leak down test and turbo seals gone.
new block fitted,valve seals,head gasket,cam seals, replacement turbos.. but has been on dyno and a puff of smoke comes out the back only on lift off after boost...:(:(
is it possible left over oil in FMIC or PIPEWORK could be cause if not cleaned out or maybe some where else from previous eng and leaks leaving oil in system somewhere??
thanks paul.. this threads in supra chat forgot to put it here:search::search:
