Speed Signal - techies please help!
Mark Ayling
I wonder if anyone can explain something to me...
Firstly, my Apexi rev/speed meter has never read above 97mph - I vaguely understand that this is something to do with the way its wired in relation to either the bit which removes the speed restriction or the kmh/mph conversion?
Secondly, on occasions, I have noticed that when on the move the rev/speed meter has shown a much too low figure, ie 7mph when I'm doing 40mph or something. Seems to be alright at the moment though, so its obviously an intermittent thing - could this also be related to a dodgy conversion?
Any info appreciated!
Cheers,
Mark.
99.9% likely cause is it's fitted to the ECU speed input wire which has a speed delimiter attached (clamping at 97mph)
Just move the wire to the other side of the speed delimiter or output from the odometer and it'll be fine.
Odd? Intermittent things like this are unusual.
Intermittent suggests wires broken etc which would be a working/non-working situation not a MPH O.K. then MPH-7mph ???
This is compared to the speedometer reading I guess, or do you have a GPS meter?
Could be the converter (please don't say it's one of mine :( )
Some converters (not mine) just blindly remove pulses from the digital pulse train to get the 5/8ths conversion. i.e. out of every 8 pulses comming in they drop 3.
i.e. 1,2,3,4,5,6,7,8 becomes 1,2,3,4,5, , , ,1,2,3,4 etc etc
Now on average the speed in reduced by 5/8ths but in reality for a digital system counting pulses this appears to be a signal bursting on and off. This could be the error you are seeing.
Just a guess.
Regards
Pete
Guest Martin F
Shall we have a wager on whether it's a Scotchlok ??
