R Black Posted May 28, 2010 Share Posted May 28, 2010 (edited) Just had my MOT done on my GZ and i failed on abs lamp not illuminating. I know i need to check the bulb, but to be fair i've never seen the ABS light lit on her since ive owned it, not felt it engage either, not sure if they are linked but trac light has never worked and i know that bulb is working. Since coming in i checked for relays and fuses, and i found these missing (marked with red stars). Anyone have any ideas? Edited May 28, 2010 by R Black (see edit history) Link to comment Share on other sites More sharing options...
wantasupra Posted May 28, 2010 Share Posted May 28, 2010 i guess your abs works, i have had the same mine never came on had a wiggle worked for a bit stopped working again, just today have unplugged the little cluster and brought it indoors ro resolder, looks like dry joints on my circuit board.got my mot next week. do the other oil lights yellow and red work fine when you put ignition on? b Link to comment Share on other sites More sharing options...
Guest ugp Posted May 28, 2010 Share Posted May 28, 2010 I wasnt aware they could fail it on that? I've had the fuse pulled from mine and it went through ok. What about if the abs was removed? Would it still fail? Link to comment Share on other sites More sharing options...
garethr Posted May 28, 2010 Share Posted May 28, 2010 I wasn't aware they could fail it on that? I've had the fuse pulled from mine and it went through ok... http://www.motinfo.gov.uk/htdocs/m3s03000401.htm Link to comment Share on other sites More sharing options...
R Black Posted May 28, 2010 Author Share Posted May 28, 2010 (edited) It didnt fail last year at the same place, had the same issues, different testers this time, but as Gareth shows it is afail if they're strict on the binnicle under the mileometer,these all light & on the left slip control off & i think its the handbrake light light also. Edited May 28, 2010 by R Black (see edit history) Link to comment Share on other sites More sharing options...
