markylee Posted May 28, 2010 Share Posted May 28, 2010 Hi guys , i have a j spec tt and i am going to go full decat soon,just wondered about the o2 sensor, their is one attatched to the manifold which is no problem, but their seems to be another one attached to the mid pipe , the pipes i have bought have no connections so what do i do with the wires coming from the midpipe , thanks for looking...........mark Quote Link to comment Share on other sites More sharing options...
Nic Posted May 28, 2010 Share Posted May 28, 2010 (edited) The one further down is the cat temp sensor (for the cat overheat warning light on dash), just cable tie it up out of the way when you fit the decat pipe, it has no effect on the running of the engine. Edited May 28, 2010 by Nic (see edit history) Quote Link to comment Share on other sites More sharing options...
markylee Posted May 28, 2010 Author Share Posted May 28, 2010 The one further down is the cat temp sensor, just cable tie it up out of the way when you fit the decat pipe. thanks Nic, id best get on with this lovely job then....blow torch at the ready:eyebrows: Quote Link to comment Share on other sites More sharing options...
