Markie Posted May 29, 2005 Share Posted May 29, 2005 Does anyone know if off the shelf HKS cams will work fine with the VVT-i as they do with the non-VVT-i's? Also, if they do, will the car require tuning before using it with the new cams or? Link to comment Share on other sites More sharing options...
Gamer Posted May 29, 2005 Share Posted May 29, 2005 HKS make a version for the VVTi... It is called the HKS Valcon Plus VCAM Kit Link to comment Share on other sites More sharing options...
Chris Wilson Posted May 29, 2005 Share Posted May 29, 2005 VVTi cars use a totally different intake cam. HKS do a controller kit (VALCON) with cams for the VVti models, it may be possible to just buy the intake cam as a spare part if you wish, and pair it with an exhaust cam, which is a common fitment throughout the model years.. I think they are 264 degrees duration in th kit, but maybe less so. Of course, a cam change should be paired with a mappable ecu, in order to modify timing and fuelling., although SOME performance gian is possible with stock ecu and cams at SOME points in the RPM band. Link to comment Share on other sites More sharing options...
Markie Posted May 29, 2005 Author Share Posted May 29, 2005 Cheers guys.. I will have a look for this VALCON kit. Link to comment Share on other sites More sharing options...
