Scott Posted May 26, 2010 Share Posted May 26, 2010 Swap you Link to comment Share on other sites More sharing options...
j_jza80 Posted May 26, 2010 Share Posted May 26, 2010 Chin up mate Link to comment Share on other sites More sharing options...
j80leo Posted May 27, 2010 Share Posted May 27, 2010 Unlucky Jay hope you get it sorted without to much hassel;) Link to comment Share on other sites More sharing options...
jevansio Posted May 27, 2010 Author Share Posted May 27, 2010 Cheers guys, Hodge is keeping me right Last night I was just so mad at a lot of things, mad I had taken the car off the road when it was running fine, mad I had rushed the job, mad I had busted a perfectly good head. Here are pics of the damage to the journal, the buckets were not going in either. I know it's not "the done thing" but I got some wet & dry, filled as much of the holes as I could with rags, & gentle went round where the buckets ran to make them a perfect fit. They're going in like the others now, & i've cleaned as much of the dirt away as possible. To complete the spring job I've made a tool myself to replace the springs, done it on the next valve with no issues whatsoever, no damage to the jounrals so I'm going to crack on Link to comment Share on other sites More sharing options...
Scott Posted May 27, 2010 Share Posted May 27, 2010 pffft, thats nothing Link to comment Share on other sites More sharing options...
hodge Posted May 27, 2010 Share Posted May 27, 2010 He'll yeah Link to comment Share on other sites More sharing options...
jevansio Posted May 27, 2010 Author Share Posted May 27, 2010 TBH it looked a lot worse last night and this is after I have tidied it up a bit Anyway I took the day off work today to sort this out I made this tool to help with fitting the springs with causing any more damage to the rest of the head. It's basically 2 old caps with a bar between, on that slides a unit with 2 bolts. I just started the cap bolts off, adjusted the other 2 bolts to meet the retainer, then tightened the cap bolts uo the rest of the way to drop spring. Worked like a charm everyttime. Got cylinders 1, 2 & 3 done with the upgraded springs & retainers. Started to rush again at one point and lost a lock down into the depths of the engine , the oil return pipe between each cylinder. John told me to get a long reach magnet & pray when I stuck it in it came out, God must have been ready to give me a break as on the 2nd time feeling around I got it, phew Link to comment Share on other sites More sharing options...
JustGav Posted May 27, 2010 Share Posted May 27, 2010 LOVE the tool Might have to make me one of those Link to comment Share on other sites More sharing options...
jevansio Posted May 27, 2010 Author Share Posted May 27, 2010 LOVE the tool Might have to make me one of those , the snap-on tool was such a pain to use, whacking it with a mallet fills you with dread every time you use it, this on the other hand is so relaxing I have some spare caps if you need em Gav Link to comment Share on other sites More sharing options...
hodge Posted May 27, 2010 Share Posted May 27, 2010 panic over then jay. I expect you showing up Sunday morning in the supra by the way. That tool is awesome. Very nice bit of kit. I want 1. TBH it looked a lot worse last night and this is after I have tidied it up a bit Anyway I took the day off work today to sort this out I made this tool to help with fitting the springs with causing any more damage to the rest of the head. It's basically 2 old caps with a bar between, on that slides a unit with 2 bolts. I just started the cap bolts off, adjusted the other 2 bolts to meet the retainer, then tightened the cap bolts uo the rest of the way to drop spring. http://www.mkivsupra.net/vbb/attachment.php?attachmentid=110945&stc=1&d=1274986306 http://www.mkivsupra.net/vbb/attachment.php?attachmentid=110946&stc=1&d=1274986306 http://www.mkivsupra.net/vbb/attachment.php?attachmentid=110947&stc=1&d=1274986306 Worked like a charm everyttime. Got cylinders 1, 2 & 3 done with the upgraded springs & retainers. Started to rush again at one point and lost a lock down into the depths of the engine , the oil return pipe between each cylinder. John told me to get a long reach magnet & pray when I stuck it in it came out, God must have been ready to give me a break as on the 2nd time feeling around I got it, phew Link to comment Share on other sites More sharing options...
AndyT Posted May 27, 2010 Share Posted May 27, 2010 Love that idea Jay. Well done mate. Pays not to rush too much doesn't it? Link to comment Share on other sites More sharing options...
wilson4347 Posted May 27, 2010 Share Posted May 27, 2010 Link to comment Share on other sites More sharing options...
SUPRALOOPY Posted May 27, 2010 Share Posted May 27, 2010 TBH it looked a lot worse last night and this is after I have tidied it up a bit Anyway I took the day off work today to sort this out I made this tool to help with fitting the springs with causing any more damage to the rest of the head. It's basically 2 old caps with a bar between, on that slides a unit with 2 bolts. I just started the cap bolts off, adjusted the other 2 bolts to meet the retainer, then tightened the cap bolts uo the rest of the way to drop spring. http://www.mkivsupra.net/vbb/attachment.php?attachmentid=110945&stc=1&d=1274986306 http://www.mkivsupra.net/vbb/attachment.php?attachmentid=110946&stc=1&d=1274986306 http://www.mkivsupra.net/vbb/attachment.php?attachmentid=110947&stc=1&d=1274986306 Worked like a charm everyttime. Got cylinders 1, 2 & 3 done with the upgraded springs & retainers. Started to rush again at one point and lost a lock down into the depths of the engine , the oil return pipe between each cylinder. John told me to get a long reach magnet & pray when I stuck it in it came out, God must have been ready to give me a break as on the 2nd time feeling around I got it, phew Loving that tool:) I have the snap on tool and Its a bit scary I have to admit:D Link to comment Share on other sites More sharing options...
JustGav Posted May 27, 2010 Share Posted May 27, 2010 I have some spare caps if you need em Gav Will take you up on that actually... Link to comment Share on other sites More sharing options...
j80leo Posted May 28, 2010 Share Posted May 28, 2010 Great job Jay good to see your back on track now just keep calm:) Link to comment Share on other sites More sharing options...
jevansio Posted May 28, 2010 Author Share Posted May 28, 2010 Will take you up on that actually... No probs, pm me your addy & I'll get a couple posted off to ya Great job Jay good to see your back on track now just keep calm:) Lol, yeah cheers mate, maybe I should have a swift vodka before doing any work to take the edge off Link to comment Share on other sites More sharing options...
j80leo Posted May 28, 2010 Share Posted May 28, 2010 Lol, yeah cheers mate, maybe I should have a swift vodka before doing any work to take the edge off It might help but just don't have too much lol:p Link to comment Share on other sites More sharing options...
jevansio Posted May 28, 2010 Author Share Posted May 28, 2010 Well I just finished the last valve, I take my hat off to Tony for completing that job with the snap-on tool, no way could I have used that. Just gotta put them cams back in & reassemble the covers & I should be ready to fire up tomorrow Link to comment Share on other sites More sharing options...
Ricky49 Posted May 28, 2010 Share Posted May 28, 2010 Good stuff mate glad it all worked out. Link to comment Share on other sites More sharing options...
hodge Posted May 28, 2010 Share Posted May 28, 2010 JAAAAAY EVANSSSSSS good work jay. Link to comment Share on other sites More sharing options...
jevansio Posted May 29, 2010 Author Share Posted May 29, 2010 She's purring like a kitten again , thanks for the support John Link to comment Share on other sites More sharing options...
johnny g Posted May 29, 2010 Share Posted May 29, 2010 Glad to hear it - now return my call Link to comment Share on other sites More sharing options...
Andy-No-Knee Posted July 26, 2010 Share Posted July 26, 2010 Can I borrow that tool you made??? I have the snap on one and have been putting this off for longer and longer as I'm somewhat concerned about it but you seem to have created the answer!!! Link to comment Share on other sites More sharing options...
dude Posted July 26, 2010 Share Posted July 26, 2010 [quote=jevansio;2770513 I have some spare caps if you need em Gav What caps do you mean dude?????? Link to comment Share on other sites More sharing options...
jevansio Posted July 26, 2010 Author Share Posted July 26, 2010 Can I borrow that tool you made??? I have the snap on one and have been putting this off for longer and longer as I'm somewhat concerned about it but you seem to have created the answer!!! Sure, send me your addy & I will send it down What caps do you mean dude?????? The cam caps (if that's what they're called ) Link to comment Share on other sites More sharing options...
