need help with crank sensor
mikeyh
I'm going to assume it's a 2JZ-GTE Engine, so hope this helps
Pages IG-11 & IG-12, for removing the Crank Position Sensor. As per Toyota Engine Manual, in the link below.
http://www.turbosupras.com/pdfs/JZA80%20TSRM/IG%20(2JZ-GTE).pdf
The Resistance of the Crankshaft Position Sensor as per the manual as follows: also Ref: Page IG-1 in the above link
Cold: 835 - 1,400 Ohms (ND)
985 - 1,600 Ohms (Aisan)
Hot: 1,060 - 1,645 Ohms (ND)
1,265 - 1,890 Ohms (Aisan)
"Cold" -10°C (14°F) to 50°C (122°F)
"Hot" 50°C (122°F) to 100°C (212°F)
(Sorry, couldn't do the dots for Degrees on the above)
Edited by GreaseMonkey
Ammended temps with SteveC tip on how to do ° (degrees dots) (see edit history)
Disconnect battery
remove aux belt
remove bolt from top of alternator
remove undertray
remove nut from bottom of alternator
slide alternator out the way.
Use a 10mm long reach 1/4 inch socket with a long extension to undo crank sensor bolt
wiggle abd gently pull sensor until it comes free from behind timing belt tensioners
repeat to refit.
Hope this helps.
