a/c oil
baldy
Quote/s from the Toyota JZA80 Chassis Body Manual.
HINT:
At the time of installation, please refer to the following item.
If condenser is replaced, add compressor oil to the condenser.
Add 40 cc (1.4 fl.oz.)
Compressor oil: ND–OIL 8 or equivalent
HINT:
If receiver is replaced, add compressor oil to receiver.
Add 10 cc (0.34 fl.oz.)
HINT:
At the time of the installation, please refer to the following item.
If evaporator is replaced, add compressor oil to evaporator.
Compresser oil: ND–OIL 8 or equivalent
I Couldn't see how much Oil the compressor would take as the compressors I've fitted were Genuine Toyota and were pre-filled with oil.
I'll have a look tomorrow at work to see if there is a part number/ price for the ND–OIL 8 as have used this recently on a job at work. It's the only stuff I used on Toyota Air Conditioning parts.
Also the Manual Shows that they take 700g +/- 50g of R134a Air Conditioning Refrigerant
Edited by GreaseMonkey (see edit history)
