JamieP Posted June 4, 2010 Share Posted June 4, 2010 Dont fit the powerflex stuff mate, i made that mistake and it wore out quicktime giving me serious handling problems, i went back to oem. Link to comment Share on other sites More sharing options...
chazuk Posted June 4, 2010 Author Share Posted June 4, 2010 Dont fit the powerflex stuff mate, i made that mistake and it wore out quicktime giving me serious handling problems, i went back to oem. Thats shocking , they are ment to be quite good thanks for the info can u remember how much you paid for oem ? I see Paul does another make of bush aswell Link to comment Share on other sites More sharing options...
JamieP Posted June 4, 2010 Share Posted June 4, 2010 I cant remember, got them from power engineering, it was a costly mistake. Link to comment Share on other sites More sharing options...
chazuk Posted June 4, 2010 Author Share Posted June 4, 2010 Managed to get the engine bay redone after work as it was still nice and warm, it will be dry by tomorrow so I will put the loom back in and some other bits, this weekends goal is doors, bootlid, rear bumper all off so I can paint the rest of the shuts. http://img532.imageshack.us/img532/50/dsc01632q.jpg http://img231.imageshack.us/img231/5947/dsc01634j.jpg http://img690.imageshack.us/img690/1639/dsc01640j.jpg Link to comment Share on other sites More sharing options...
AndyT Posted June 4, 2010 Share Posted June 4, 2010 Crikey. You're not hanging around Chaz. Good stuff. Link to comment Share on other sites More sharing options...
hiten55 Posted June 4, 2010 Share Posted June 4, 2010 looks like a good build, cant wait to see it complete Link to comment Share on other sites More sharing options...
chazuk Posted June 4, 2010 Author Share Posted June 4, 2010 Crikey. You're not hanging around Chaz. Good stuff. it does not look like allot of work but I am surprised I just keep taking more and more bis off and masking up takes a age still it will be worth it. looks like a good build, cant wait to see it complete me to mate , starting to kick myself already for doing it over summer though still I had to start sometime. Link to comment Share on other sites More sharing options...
Fitz Posted June 4, 2010 Share Posted June 4, 2010 Looking good so far Bud Seems like a good, steady work rate. That white will look stunning. Link to comment Share on other sites More sharing options...
chazuk Posted June 5, 2010 Author Share Posted June 5, 2010 Looking good so far Bud Seems like a good, steady work rate. That white will look stunning. Cheers mate , Todays update , Loom and bits back in http://img534.imageshack.us/img534/4723/img00022201005311045.jpg http://img532.imageshack.us/img532/7159/img00023201005311045.jpg Removing all rubbers and trim http://img243.imageshack.us/img243/3043/img00027201006021445.jpg http://img514.imageshack.us/img514/8664/img00032201006031121.jpg http://img534.imageshack.us/img534/8382/img00031201006031121.jpg http://img99.imageshack.us/img99/3029/dsc01677tv.jpg Found some surface rust under the aeroroof seal rubbed down and treated with anti rust http://img171.imageshack.us/img171/7008/dsc01678d.jpg http://img412.imageshack.us/img412/7585/dsc01675m.jpg Bought some packs of nuts and bolts and washers , will replace everything with new , these were 10 quid a pack bargin I though for 300bits in each http://img405.imageshack.us/img405/7332/img00033201006031545.jpg Link to comment Share on other sites More sharing options...
chazuk Posted June 8, 2010 Author Share Posted June 8, 2010 Finished the shuts, this coming weekend I will do behind the doors and underneath of boot / bonnet then I can bolt these back on and thats my bit of the painting done. I went over onto the body on purpose by a couple of mm just so when the car is rubbed down with the boot and doors back the shut /spray line is covered so no thin sliver line will appear. http://img36.imageshack.us/img36/2791/dsc01681ak.jpg http://img691.imageshack.us/img691/5927/dsc01699v.jpg http://img192.imageshack.us/img192/2347/dsc01687u.jpg http://img19.imageshack.us/img19/7757/img00038201006050938.jpg http://img688.imageshack.us/img688/7233/dsc01706po.jpg http://img14.imageshack.us/img14/8572/img00037201006042035.jpg http://img35.imageshack.us/img35/7582/dsc01705ub.jpg Link to comment Share on other sites More sharing options...
chazuk Posted June 24, 2010 Author Share Posted June 24, 2010 (edited) quick update http://img28.imageshack.us/img28/9730/img00051201006111446.jpg http://img23.imageshack.us/img23/6623/img00058201006151421.jpg http://img294.imageshack.us/img294/6278/dsc01719k.jpg http://img130.imageshack.us/img130/3986/dsc01715r.jpg Boot lid sprayed http://img683.imageshack.us/img683/2606/img00066201006171240.jpg Had some paint left over found the prop shaft . http://img820.imageshack.us/img820/4246/dsc01710c.jpg Hub and arms off http://img526.imageshack.us/img526/2679/img00072201006211541.jpg Degreased http://img97.imageshack.us/img97/8446/img00071201006211541.jpg Nightmare to mask up the ksport logo but I got there in the end doing it this way. http://img718.imageshack.us/img718/4861/img00073201006231240.jpg Busk kit fitted sorry theres no pics of this I will do it for the otherside I decided to stick with powerflex if I have to replace them in under 10k miles then atleast it will be easier to change plus I had already got them , I used a hole cutter to cut the bushes out had to buy the right size but they just fall out this way ,then used a hacksaw to remove the metal insert, also painted hub and arms and undersealed the whole arch. http://img205.imageshack.us/img205/5738/dsc01726m.jpg http://img156.imageshack.us/img156/3595/dsc01733k.jpg http://img265.imageshack.us/img265/1750/dsc01734st.jpg Edited June 24, 2010 by chazuk (see edit history) Link to comment Share on other sites More sharing options...
j_jza80 Posted June 24, 2010 Share Posted June 24, 2010 Looking good What type of paint have you used on the calipers? Link to comment Share on other sites More sharing options...
chazuk Posted June 24, 2010 Author Share Posted June 24, 2010 Looking good What type of paint have you used on the calipers? Cheers mate , same as the car really used a primer , then basecoat white, then 2 k clear lacquer. I have always done it this way in the past and the paint has never come off due to heat , good thing is with the clear coat the brakedust does not eat into the colour and its easy to clean. Link to comment Share on other sites More sharing options...
j_jza80 Posted June 24, 2010 Share Posted June 24, 2010 Cheers mate , same as the car really used a primer , then basecoat white, then 2 k clear lacquer. I have always done it this way in the past and the paint has never come off due to heat , good thing is with the clear coat the brakedust does not eat into the colour and its easy to clean. What is 2 k clear laquer exactly? Link to comment Share on other sites More sharing options...
chazuk Posted June 24, 2010 Author Share Posted June 24, 2010 What is 2 k clear laquer exactly? Its UPOL mate Link to comment Share on other sites More sharing options...
chazuk Posted November 6, 2010 Author Share Posted November 6, 2010 (edited) Its been awhile so time for a update , Bits bought since Competition stage 4 clutch and lightened flywheel Driftworks 19 row oil cooler with thermostat Q45 90mm throttle body Top secret carbon bonnet Top secret side skirts Carbon plug cover Fuel pulsation damper removal line New front and rear anti roll bar links Boost logic 4 exhaust New front tie rod ends HKS ssqv Demonsports inlet manifold Arp studs New headgasket Bosch 44 pump and fitting kit Greddy 3 row intercooler and pipe kit Oil cooler for pas I knew some of my valve stem seals had gone so dropped engine off to Dude at AFR who did a top job , while the head was off arp studs a new headgasket and cambelt was done. Here is the engine back http://img220.imageshack.us/img220/786/img00114201009040914.jpg Rear suspension poly bushed painted new ball joint boots and ready to go back on. I have lost quite a few pictures but I sent the rear hubs off to Chris to have new toyota bearings and seals fitted Chris also checked my flanges but these were okay , thanks again Chris superfast turnaround. The diff got a make over aswell did the whole rear end same as the front I will re take some pic's but its all bolted up now:) http://img143.imageshack.us/img143/5378/img00143201010151356.jpg Got a local company to powder coat the runners , q45 and the cam covers sorry they are missing in this pic . Colour met black gloss. http://img215.imageshack.us/img215/5889/dsc02164el.jpg Gear box ready to go back in http://img543.imageshack.us/img543/6340/img00163201011041128.jpg Turbo kit on and inlet manifold http://img844.imageshack.us/img844/3120/dsc02169q.jpg This is what I ment Paul regarding the metal tabs on the standard cover http://img225.imageshack.us/img225/6183/img00159201011040939.jpg Used a block and tackle rather than a engine crane much more control I thought http://img688.imageshack.us/img688/8972/dsc02194m.jpg http://img811.imageshack.us/img811/3713/dsc02195q.jpg http://img411.imageshack.us/img411/2549/dsc02201x.jpg Started to re route the loom and relocate the fuse box just see it in the bottom right. http://img824.imageshack.us/img824/415/dsc02202pr.jpg Edited November 6, 2010 by chazuk n/a (see edit history) Link to comment Share on other sites More sharing options...
Paul Whiffin Posted November 8, 2010 Share Posted November 8, 2010 This is what I ment Paul regarding the metal tabs on the standard cover http://img225.imageshack.us/img225/6183/img00159201011040939.jpg Hello mate, thats not a standard clutch cover, you dont need that bit you were talking about anyway. Looking good, coming along nicely. Ta Link to comment Share on other sites More sharing options...
Nicolai Posted November 8, 2010 Share Posted November 8, 2010 Thats some car porn right there! Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted November 8, 2010 Share Posted November 8, 2010 lovely looking engine bay mate, might have flicked past it but what turbo/ kit is that?? Link to comment Share on other sites More sharing options...
chazuk Posted November 8, 2010 Author Share Posted November 8, 2010 Hello mate, thats not a standard clutch cover, you dont need that bit you were talking about anyway. Looking good, coming along nicely. Ta Cheers mate thanks again for the advice. lovely looking engine bay mate, might have flicked past it but what turbo/ kit is that?? Cheers dude , its a Whifblitz bw 91/79 0.91 A/R single kit took me a while to decide but the bw kits have made some good power and Paul offers a warranty on the manifolds to. Link to comment Share on other sites More sharing options...
chazuk Posted November 8, 2010 Author Share Posted November 8, 2010 a few more pic's http://img263.imageshack.us/img263/5060/dsc02228x.jpg Gearbox back in http://img143.imageshack.us/img143/6352/dsc02231f.jpg http://img146.imageshack.us/img146/46/dsc02217f.jpg http://img230.imageshack.us/img230/9841/dsc02241g.jpg Plan is to paint the bonnet and just have the blades left in carbon http://img574.imageshack.us/img574/8572/dsc02242.jpg After a while I found routing the wiring this way none of the chunky wiring loom has to be cut just the lights and abs and to 2 block connectors going to the engine will need to be made longer still allot of work to do to make it all neat. Link to comment Share on other sites More sharing options...
chazuk Posted April 12, 2011 Author Share Posted April 12, 2011 Small update well after some time I have finally got it out of the garage just a mess left behind I think before it goes back in time to lay a latex floor down as its a bit worse for wear the old concrete one:) http://img132.imageshack.us/img132/4467/dsc02747x.jpg I will change the silcone to black but blue was supplied so blue got fitted , just waiting on a boostlogic 3bolt to 4 vband exhaust adapter ,fpr and q45 tps adapter and 2 bits of silcone to finish the fmic a breather catch tank and lines and it should start http://img851.imageshack.us/img851/456/dsc02732p.jpg Driftworks oil cooler and stock uk spec diff oil cooler http://img862.imageshack.us/img862/1706/dsc02734z.jpg Driftworks oil block and hks filiter also fitted heavy duty magentic sump plug http://img857.imageshack.us/img857/1905/img00043201104111013.jpg Bosch 44 pump fitted picture not finished took while in progress old pump a walbro http://img818.imageshack.us/img818/4237/img00012201102071531.jpg Fused distriubution block 200amp wiring is now finished now apart from I might need to make the headlight connectors a bit longer at the front but I think they might reach, used a 4 gauge heavy shielded cable to run battery to the boot via the inside of the car http://img691.imageshack.us/img691/1798/dsc02737yt.jpg Cicuirt breaker 200amp http://img64.imageshack.us/img64/2136/dsc02738j.jpg Just need a small sealed battery now that will fit in the standard sub hole http://img856.imageshack.us/img856/1041/dsc02740t.jpg Pioneer sat nav /hands free double din will help to finish off the interior http://img856.imageshack.us/img856/153/dsc02748h.jpg Apr rad pannel bit of engine bay bling http://img508.imageshack.us/img508/5958/dsc02749l.jpg Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted April 12, 2011 Share Posted April 12, 2011 looking great mate, i cant wait to get my turbo ordered. Link to comment Share on other sites More sharing options...
chazuk Posted April 12, 2011 Author Share Posted April 12, 2011 looking great mate, i cant wait to get my turbo ordered. Cheers mate what turbo you going with ? Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted April 12, 2011 Share Posted April 12, 2011 im going for the S362 mate, should work great on the autobox. quick question- where do the two vaccum pipes go which come off the lower power steering union? Link to comment Share on other sites More sharing options...
