P&H driver wiring advice.
Terminator
Having RLTC I believe that I should wire the input feeds to a P&H driver after the RLCT connections. So in line it would be ECU out puts trigger voltage, RLTC allows or cuts voltage, so P&H driver receives either 0volts or trigger signal.
Can someone confirm.
All sorted now. 280510
Edited by Terminator
Problem solved (see edit history)
