tDR Posted January 30, 2009 Share Posted January 30, 2009 TOTB9 It's that time again... time to get our team entry together for this - who's up for it? Would like to see a strong team representing the Supras this year so please add your name to the list below if you'd like to compete and your PROVEN drag times so far. There's also the handling and top speed elements to consider so top speed heroes and track ready stripped type Supra's will also be considered on merit: 1. [10's] Dude (T74, 6-Sp, Built Motor) 2. [10's] Steve Sherwood (GTK1000, 6-Sp, Built Motor) 3. [??] M5W TT (Track stripped, T67, 6-Sp, Built Motor) 4. 5. 6. 7. 8. 9. 10. Put yourself on the above list based on your time from fastest at the top to slowest at the bottom or if you want to be considered as a top speed or circuit specialist then put your name at the bottom with [TOP SPEED] or [CIRCUIT] in front of it. Also could you include some basic spec info and power level in your entry line. Example entry lines showing formatting: 1. [9.87] The Roadrunner (T71, BL trans, PI 4K Stall) 2. [CIRCUIT] The Stig (Stripped, caged, full underbody aero, TRD diff, Ohlins Coilovers) 3. You get the idea. See www.totb.co.uk for full info. I've stickied this thread to keep it at the top and we'll devise a final team entry shortly before the final closing date for entries at the start of July, based on the above list. CLOSING DATE for all entries is 3rd July 2010. Entry form attached to this post. *** UPDATE 30/05/10 - Amended team list *** *** UPDATE 23/06/10 - Amended team list *** Cheers, Brian.2010TOTBRegistration.pdf Quote Link to comment Share on other sites More sharing options...
tDR Posted January 30, 2009 Author Share Posted January 30, 2009 ADVICE FOR OUR TEAM ENTRANTS: You need to run decent fuel and decent tyres on the day at TOTB!!! Why? Because aside from the performance enhancing benefits race fuel helps protect against det and it's always bloody HOT on the day at TOTB which is the kinda weather when det is most likely to happen, and the surface is pretty crappy at Elvington so you need to run the best tyres you can on the surface. I'd like to see all our guys running drag radial type tyres or track specials like Toyo R888's (either has to be road legal) and some race fuel in your tanks. Places to get these items: Race Fuel: http://www.aaoil.co.uk/racing-Sunoco-GT-PLUS (109RON, 4.5% oxygenated - this is the easiest stuff to run as it's unleaded and still decent octane / oxygenation) http://www.aaoil.co.uk/racing-Sunoco-MaxNOS (Highest octane of the Sunoco range at 119RON but leaded and not oxygenated) Competition Tyres: http://www.laracingparts.com/ http://laracingparts.com/acatalog/Mickey_Thompson_E_T__Street_Radial_Tires.html (275/40/17 will fit on UK spec rear rims, 255/50/16 should fit on J spec rear rims) http://www.tirerack.com/tires/tires.jsp?tireMake=BFGoodrich&tireModel=g-Force+T%2FA+Drag+Radial (You can get these from here via Dusty @ MVP, this model is new and basically is easier to use with less burnout being required to get them up to temp) http://www.tirerack.com/tires/tires.jsp?tireMake=BFGoodrich&tireModel=g-Force+T%2FA+Drag+Radial+2 (As above for ordering, these are the originals previously called 'Pro Comp T/A' and require a bit of heating up to hook up well) Another supplier some members have used for both Tyres and Fuel is Webster Race Engineering: http://www.webster-race-engineering.co.uk [email protected] 01933 315236 Their website isn't up to much so best emailing or phoning them. Hope this helps guys.... get ordering Quote Link to comment Share on other sites More sharing options...
tDR Posted May 25, 2010 Author Share Posted May 25, 2010 TEST DAY Please note there is also a test day the day before the event - Saturday 7th August 2010 - that some of you may wish to attend also for setup optimisation / general practice etc. Just state which you wish to enter for on the entry form in the first post and include a cheque for the appropriate total amount as per the website: To enter the TOTB warm up day (Saturday 7th August 2010) total cost £60 To Enter TOTB9 (Sunday 8th August 2010) is £100 To enter both days (Saturday 7th & Sunday 8th August 2010) total cost £140 Please make all cheques payable to STRAIGHTLINERS LTD Quote Link to comment Share on other sites More sharing options...
T2 MSW Posted May 25, 2010 Share Posted May 25, 2010 I'd like to enter as a reserve incase we don't get the numbers. M5W TT circuit striped cage 611bhp Quote Link to comment Share on other sites More sharing options...
rob wild Posted May 25, 2010 Share Posted May 25, 2010 I'd like to enter as a reserve incase we don't get the numbers. M5W TT circuit striped cage 611bhp Though you might put your name down Good Man! Come on folks roll up roll up! Quote Link to comment Share on other sites More sharing options...
Jamesy Posted May 25, 2010 Share Posted May 25, 2010 We've got enough properly sorted supras on here now to put up a good fight at TOTB this year. Will hopefully come on the day to watch Quote Link to comment Share on other sites More sharing options...
tDR Posted May 25, 2010 Author Share Posted May 25, 2010 Yeah we certainly have - we could really clean up on the Top Speed event and accumulate a lot of team points as a result if we get a certain few members who 0wned that recent top speed event... M5W - thanks for the entry I'm more interested in members that are really going to commit to the event than anything as I'm fed up with drop outs near the entry date in previous years so if you're serious there's a spot with your name on it. Quote Link to comment Share on other sites More sharing options...
T2 MSW Posted May 25, 2010 Share Posted May 25, 2010 Let me get the cage and brakes sorted and Ill definatly commit to a place. Quote Link to comment Share on other sites More sharing options...
tDR Posted May 25, 2010 Author Share Posted May 25, 2010 Last year's Top Speed category winner done 189MPH over the standing mile..... surely we can top that these days? Quote Link to comment Share on other sites More sharing options...
Homer Posted May 25, 2010 Share Posted May 25, 2010 This club always does terrible at TOTB, unlike most big other clubs few seem to show much interest Dude was about the only one that ever got anywhere in it! Shame really as we really should do quite well at the drag and top speed events. Quote Link to comment Share on other sites More sharing options...
T2 MSW Posted May 25, 2010 Share Posted May 25, 2010 This club always does terrible at TOTB, unlike most big other clubs few seem to show much interest Dude was about the only one that ever got anywhere in it! Shame really as we really should do quite well at the drag and top speed events. Thats not really inspiring confidence seeing as im already worried about performace lol Quote Link to comment Share on other sites More sharing options...
tDR Posted May 25, 2010 Author Share Posted May 25, 2010 I'm available as a hired driver BTW for those that perhaps have a decent car but would prefer not to abuse it themselves - will work for cans of diet coke... Quote Link to comment Share on other sites More sharing options...
Homer Posted May 25, 2010 Share Posted May 25, 2010 Thats not really inspiring confidence seeing as im already worried about performace lol It's not that our cars are slow, far from it, it's just than very few actually go there in the first place hence our poor results as a club. Good on you for giving it a go, top speed is one where this club really should do well. Quote Link to comment Share on other sites More sharing options...
dude Posted May 25, 2010 Share Posted May 25, 2010 Put me down, I wouldnt miss this for the world. Quote Link to comment Share on other sites More sharing options...
rob wild Posted May 25, 2010 Share Posted May 25, 2010 It's not that our cars are slow, far from it, it's just than very few actually go there in the first place hence our poor results as a club. Good on you for giving it a go, top speed is one where this club really should do well. Totally agree and from years of going to TOTB its not all about power either! Driver skill plays a huge part! I finally have a motor that might be competitive is just I have no skill and its not a Supra Put me down, I wouldnt miss this for the world. Though you might! Yours will do well! Quote Link to comment Share on other sites More sharing options...
Jurgen-Jm-Imports Posted May 25, 2010 Share Posted May 25, 2010 jamie p , lee p come on guys there must be few other guys willing to have a bash Quote Link to comment Share on other sites More sharing options...
JamieP Posted May 25, 2010 Share Posted May 25, 2010 Im not interested in running at totb for many reasons. Quote Link to comment Share on other sites More sharing options...
Fitz Posted May 25, 2010 Share Posted May 25, 2010 lots of ballsy drivers on here with Big numbers. Should be a easy trophy for MKIVSupra.net Quote Link to comment Share on other sites More sharing options...
Jurgen-Jm-Imports Posted May 25, 2010 Share Posted May 25, 2010 Im not interested in running at totb for many reasons. how come mate , i think you will do well Quote Link to comment Share on other sites More sharing options...
JamieP Posted May 25, 2010 Share Posted May 25, 2010 how come mate , i think you will do well I could list out all the reasons but i cant be bothered with all the replys and questions tbh, no point in mentioning my name in this thread, i wont be there. Quote Link to comment Share on other sites More sharing options...
tDR Posted May 25, 2010 Author Share Posted May 25, 2010 Put me down, I wouldnt miss this for the world. Bril - good to have you on the team again m8! Could you gimme an entry line like the 1st post? Need to try to record some info for everyone. Quote Link to comment Share on other sites More sharing options...
tDR Posted May 25, 2010 Author Share Posted May 25, 2010 Im not interested in running at totb for many reasons. Sucks Would love to have you on the team Jamie! Same goes for Lee - be good promotion for SRD too given media exposure etc. Quote Link to comment Share on other sites More sharing options...
dude Posted May 25, 2010 Share Posted May 25, 2010 Bril - good to have you on the team again m8! Could you gimme an entry line like the 1st post? Need to try to record some info for everyone. What like 1) Dude, single turbo, 6 speed, power...adequate;) Quote Link to comment Share on other sites More sharing options...
tDR Posted May 25, 2010 Author Share Posted May 25, 2010 Like: [9.87] The Roadrunner (T71, BL trans, PI 4K Stall) ^^ Want some specifics ideally including best 1/4 to date with the car and turbo model at least - gives an idea of what to expect that way Quote Link to comment Share on other sites More sharing options...
dude Posted May 26, 2010 Share Posted May 26, 2010 Like: [9.87] The Roadrunner (T71, BL trans, PI 4K Stall) ^^ Want some specifics ideally including best 1/4 to date with the car and turbo model at least - gives an idea of what to expect that way Thats about the best you will get!!! Why tell everyone what spec your running:blink: The 1/4 times will have to wait till we run the car. Quote Link to comment Share on other sites More sharing options...
