teddan Posted May 25, 2010 Share Posted May 25, 2010 how much does a bpu kit cost? Quote Link to comment Share on other sites More sharing options...
Guest Supra-T Posted May 25, 2010 Share Posted May 25, 2010 It varies mate Quote Link to comment Share on other sites More sharing options...
DaveR Posted May 25, 2010 Share Posted May 25, 2010 It depends which company you get to do it for you and what exact spec you go for. Mine was around 4.5k with all parts (all HKS kit including FMIC) and labour at TDi. Quote Link to comment Share on other sites More sharing options...
Jurgen-Jm-Imports Posted May 25, 2010 Share Posted May 25, 2010 It depends which company you get to do it for you and what exact spec you go for. Mine was around 4.5k with all parts (all HKS kit including FMIC) and labour at TDi. Quote Link to comment Share on other sites More sharing options...
johnny g Posted May 25, 2010 Share Posted May 25, 2010 Jesus H ... that's crazy money for BPU Quote Link to comment Share on other sites More sharing options...
Robzki Posted May 25, 2010 Share Posted May 25, 2010 (edited) It varies an awful lot tbh. everyone has a different idea of the full bpu spec. Some say you 'need' afr, egt and boost gauges which could be £30 each or £150 each. some say you only need a boost gauge(not advisable) some fit a new fuel pump others don't. Different plugs etc etc. I've bought all secondhand(not fitted yet) and so far has cost less than £500 without the fuel pump but did include 1st and second decat, catback exhaust, sard sports cat, greddy fuel cut limiter, greddy egt and boost gauges, different plugs. Its whatever you want to spend in my opinion. I would love a fmic but mainly for the looks. a good condition oem intercooler is more than sufficient for bpu. The fuel pump is again, a matter of opinion. they are getting on a bit now, but keep an eye on the afr and should be ok. For the cost it is advisable to change though. Rob And £4500 for bpu is truly staggering.......... but it does show that it could be anywhere between £500 and £5000 Edited May 25, 2010 by Robzki (see edit history) Quote Link to comment Share on other sites More sharing options...
TTRickeh Posted May 25, 2010 Share Posted May 25, 2010 It depends which company you get to do it for you and what exact spec you go for. Mine was around 4.5k with all parts (all HKS kit including FMIC) and labour at TDi. Quote Link to comment Share on other sites More sharing options...
Jurgen-Jm-Imports Posted May 25, 2010 Share Posted May 25, 2010 if it was complete stock then cost sound more reasonable but 4.5k is a lot of money Quote Link to comment Share on other sites More sharing options...
AlanM Posted May 25, 2010 Share Posted May 25, 2010 It depends which company you get to do it for you and what exact spec you go for. Mine was around 4.5k with all parts (all HKS kit including FMIC) and labour at TDi. That is expensive Quote Link to comment Share on other sites More sharing options...
miko_supra Posted May 25, 2010 Share Posted May 25, 2010 sorry but 4.5k is a hell of allot! minimum parts you need from stock would be around a grand, and then plus any labour. Quote Link to comment Share on other sites More sharing options...
Kim1978 Posted May 25, 2010 Share Posted May 25, 2010 you can save a lot of cost if you look in the sale thread and buy used parts as well. The most basic things you need is a fuel pump, downpipe, bcc and boost controller. You should be able to get that for £500. Myself spent somewhat closer to £2,000 and I got almost all my parts used. This is my BPU setup HKS 4" Ti Greddy 3 row Apexi AVCR RMM DP Max Air Box Intake Adjustable Cam Gears Quote Link to comment Share on other sites More sharing options...
tbourner Posted May 25, 2010 Share Posted May 25, 2010 I think another big cost factor is whether or not your SMIC is up to the job, and then whether you go for a new SMIC or a FMIC. Quote Link to comment Share on other sites More sharing options...
johnny g Posted May 25, 2010 Share Posted May 25, 2010 For BPU, the new Whifbitz cooler is ideal Quote Link to comment Share on other sites More sharing options...
tbourner Posted May 25, 2010 Share Posted May 25, 2010 You can get BPU by just taking your cats out and replacing them with some pipe. It won't last long though! Quote Link to comment Share on other sites More sharing options...
Abz Posted May 25, 2010 Share Posted May 25, 2010 It depends which company you get to do it for you and what exact spec you go for. Mine was around 4.5k with all parts (all HKS kit including FMIC) and labour at TDi. That does seem a lot unless you had other things done to the car like service & parts changed. To the OP, what parts do you have in mind as price will vary. Quote Link to comment Share on other sites More sharing options...
Nic Posted May 25, 2010 Share Posted May 25, 2010 (edited) Price this little lot up and you'll have your answer 1st Decat Pipe - Required 2nd Decat Pipe - Required Resistor Ring - Required Cat Back Exhaust - Required Boost Gauge - Required Fuel Cut Defender - Required Spark Plugs - Cooler grade required Intercooler - Depending on condition of stock SMIC EGT/AFR Gauge - Optional but recommended Gauge Pod - Optional Boost Controller - Optional Labour Edited May 25, 2010 by Nic (see edit history) Quote Link to comment Share on other sites More sharing options...
teddan Posted May 25, 2010 Author Share Posted May 25, 2010 so could be around 1000 then I am going to do the fitting myself Quote Link to comment Share on other sites More sharing options...
nigelboyne Posted May 25, 2010 Share Posted May 25, 2010 i spent 5k plus going full bpu a hks typr r intercooler is 1200 pound on its own Quote Link to comment Share on other sites More sharing options...
Lbm Posted May 25, 2010 Share Posted May 25, 2010 (edited) I think I paid around £2000 to have the following supplied and fitted... The kit without the exhaust came to approximately £1200 inc VAT (May 2008) Blitz Nurspec RX Exhaust Greddy FMIC I wanted to type Greedy just to be annoying Plugs Boost Controller Double decat Walbro pump FCD Everything supplied and fitted by Whifbitz (except exhaust fitment) Edited May 25, 2010 by Lbm (see edit history) Quote Link to comment Share on other sites More sharing options...
Snooze Posted May 25, 2010 Share Posted May 25, 2010 On the Aristo, I did: - custom full exhaust - plugs - boost controller - FCD Exhaust work and installation work was all cash-in-hand. Total spend ~£1k. Quote Link to comment Share on other sites More sharing options...
miko_supra Posted May 25, 2010 Share Posted May 25, 2010 If you want to keep costs down have a look at whifbitz exhausts. They are around £200 cheaper than the branded ones. Quote Link to comment Share on other sites More sharing options...
Robzki Posted May 25, 2010 Share Posted May 25, 2010 i spent 5k plus going full bpu a hks typr r intercooler is 1200 pound on its own So minus the intercooler that makes £3800 for bpu? what did you get for the money? what was the labour cost? Out of genuine interest, I must have bought 'cheap' parts tbh Quote Link to comment Share on other sites More sharing options...
magictorch Posted May 25, 2010 Share Posted May 25, 2010 i spent 5k plus going full bpu a hks typr r intercooler is 1200 pound on its own Same here....mostly on parts as well........wouldnt like to add it up:D Quote Link to comment Share on other sites More sharing options...
Luxluc Posted May 25, 2010 Share Posted May 25, 2010 http://whifbitzperformancetuning.co.uk/toyota-supra-performance-packs-c-42_47_836.html Quote Link to comment Share on other sites More sharing options...
nigelboyne Posted May 25, 2010 Share Posted May 25, 2010 (edited) hks high power exhaust 500 pounds hks evc 6 400 pounds greddy fcd 80 pounds hks second decat pipe 140 pounds labour 720 pounds that was first trip to tdi. so 1800 pounds. 2ND trip to tdi type r hks intercooler 1200pounds hks sqv2 plus recirculating plus mesh 280 pounds labour 640 pounds 2100pounds.so were are at nearly 4K. i got some parts delivered then fuel pump 200 pound fuel filter 30 pound hks cam pulleys 200 pounds hks belts ie timing and aux 150 pounds alloy pipe for intercooler 40 pounds tein springs200 pounds tein strut bars front rear 250 pounds cam belt tensioner plus idler 150 pounds plus 300 pounds have fitted roughly 1500 pounds. so up to 5.5 k. 3RD trip to tdi hks fcon v pro 850 pounds hks wide band pressure sensor 150 pounds hks vpc temp sensor 30 pounds hks harness air temp 25 pounds hks fcon 5 harness 270 pounds.1400 pounds so nearly 7k. new clutch cover disc realease bearing rear main oil seal 300 pounds.labour to remove and install clutch plus full remap raise limiter to 7200rpm afr 11.4.1 boost 1.1bar /1.45bar 1700pounds so SORRY AROUND 8K FOR FULL BPU Edited May 25, 2010 by nigelboyne (see edit history) Quote Link to comment Share on other sites More sharing options...
