Check your brake lines immediatley!!
Maxx
I'm sure this has been brought up before, but I feel obliged to do so again.
Whilst in the process of doing a ground up renovation of my supe I noticed one of my rear brake lines was massively corroded and on closer inspection actually began to leak. Thank God it was off the road.
I regularly check my supe including all brake and fuel lines, they had shown no signs of corrosion until I removed the plastic cover over the rear crossmember. This apparently provides a perfect environment for corrosion.
I strongly recommend that all of you check (or have someone check) this particular location ASAP!!
See the photos below for location and what you may find:
Cheers Smarty, scary thing was the rest of the lines looked absolutely fine, don't like to think about what might of happened had it not been off the road!
I guessed it would have been covered already, but just wanted to bring it to everyones attention again as this seems to be a serious problem that I'm sure will happen on most of the supras out there sooner or later unless dealt with. Glad the pics are useful too.
Edited by Maxx (see edit history)
Only six months ago Swampy, to be fair the lines all looked fine wasn't until the the plastic cover was removed that I found the problem. It didn't start leaking till I started to remove the cover either so all appeared, on the surface, to be fine.
That's the worrying thing Swampy, you really wouldn't suspect any problems looking at the exposed sections of lines. I can't stress enough the importance of actually removing the plastic cover and checking this section of pipe/tube, I was amazed at the level of localised corrosion!
