sathorburn Posted May 28, 2005 Share Posted May 28, 2005 Can anyone run through how to get the front bumper off of a 1996 jap import SZ. I tried today, took the three bolts from both wheel arches, 6 bolts from under the bumper and it was still solid. Please help Quote Link to comment Share on other sites More sharing options...
absz Posted May 28, 2005 Share Posted May 28, 2005 you also need to remove both headlights and theres two more nuts either side Quote Link to comment Share on other sites More sharing options...
sathorburn Posted May 28, 2005 Author Share Posted May 28, 2005 where are the other two nuts? Quote Link to comment Share on other sites More sharing options...
Timwildman Posted May 28, 2005 Share Posted May 28, 2005 you can do it without taking the headlights out, but it's so much easier. The nuts hold on studs that are at the top of the rear edge both sides. Quote Link to comment Share on other sites More sharing options...
sathorburn Posted May 29, 2005 Author Share Posted May 29, 2005 cheers for the tips, i'll have another look Quote Link to comment Share on other sites More sharing options...
merckx Posted May 29, 2005 Share Posted May 29, 2005 you can do it without taking the headlights out, but it's so much easier. The nuts hold on studs that are at the top of the rear edge both sides. The ones at the back are the awkward ones! Quote Link to comment Share on other sites More sharing options...
Timwildman Posted May 29, 2005 Share Posted May 29, 2005 The ones at the back are the awkward ones! I'm used to using my hands in tight holes so didn't find it too hard with the lights in lol. Hope the attachment helps a bit. Quote Link to comment Share on other sites More sharing options...
colsoop Posted May 29, 2005 Share Posted May 29, 2005 Have you removed the plastic screws that sit underneath the rubber where the bumper meets the bonnet? Quote Link to comment Share on other sites More sharing options...
lovatt Posted May 29, 2005 Share Posted May 29, 2005 dont forget the 6 plastic clips in the mouth opening for the rad if its a stock bumper Quote Link to comment Share on other sites More sharing options...
sathorburn Posted May 29, 2005 Author Share Posted May 29, 2005 have not done any of that. looks like the rest of my sunday is taken up. Thanks guys, most appreciated Quote Link to comment Share on other sites More sharing options...
garetheves Posted May 29, 2005 Share Posted May 29, 2005 Good luck mate. i did this when i was fitting my mesh and it literally took most of the day to take off. On the plus side, once you know where all the screws go, it only takes half hour to put back on. IIRC there were 2 in the engine bay, 3 just in front of each wheel and the six inside the mesh area. think thats all but i could well be wrong. My memory aint my strong point. Quote Link to comment Share on other sites More sharing options...
