RussVVTi6Speed Posted August 18, 2011 Author Share Posted August 18, 2011 I turned the A/C on last night, with the bonnet open so i could see if the pump was spinning, As the the engine revs peak, the inner wheel on the pump starts to turn, so maybe not ceased completley, then the revs drop and inner wheel of the pump then stops again. Very strange. Link to comment Share on other sites More sharing options...
Chris Wilson Posted August 18, 2011 Share Posted August 18, 2011 It's low on gas, it needs re charging after having it checked for leaks. Link to comment Share on other sites More sharing options...
RussVVTi6Speed Posted August 19, 2011 Author Share Posted August 19, 2011 It's low on gas, it needs re charging after having it checked for leaks. Chris is that what you are saying could be the problem with mine? Link to comment Share on other sites More sharing options...
Chris Wilson Posted August 19, 2011 Share Posted August 19, 2011 Chris is that what you are saying could be the problem with mine? Yep. Link to comment Share on other sites More sharing options...
