A/C on, makes car idle inconsistently.
RussVVTi6Speed
Strange one this.
When I turn the A/C the car start idling horribly, going up and down from 300rpm to then 600rpm each second. This carries on until i turn the a/c off. If i leave it one it continues until there seems to be a cut-off which then just tunrs the a/c off after about 30 seconds.
Anyone had this before or indeed know the fix.
Would be grateful of your help especially due to the weather at the moment....typical ....lol
Thasnks guys
can you get your hand down onto the inner section of the pulley?
you should be able to turn it with your hand, it will be reasonably stiff, but it could be semi seized.....
alternative to that is watch the inner pulley whilst someone else presses the aircon on/off in the car....off it should be stationary on it should audibly 'clunk' and spin at the same rate as the outer pulley
Presumably you should only attempt this with the engine off !
Mike
Revs should increase when the A/C kicks in. The ECU compensates for the extra load on the engine and increases the idle via the IACV.
Aftermarket ECU's may not have been set up to do this, in which case the idle will drop when the A/C pump kicks in.
I have no idea about the hunting, but tending to agree with Scooter about a siezing/faulty A/C pump.
Kin ell a blast from the past:search::p
  • 1 year later...
