Removing Boostlogic Crank Pulley
jevansio
I know there are LOADS of post on removing crank pulleys which I have read, but this is specific to the Boostlogic pulley.
To remove the nut, can I make a SST which bolts onto the pulley and stops it rotating while I undo the nut.
I've taken a photo of the pulley with 3 options of where to bolt such a device.
1. Remove what looks like some 6 original bolts & use those positions.
2. Use some of the 6 bolt holes between the original bolts that have not been used
3. Use 4 outer bolt holes which seem of a larger diameter
Would appreciate some advice incase I do something I shouldn't & break it :D
