Rear upper suspension arm bushes
Scutch0
Are they a big job to change? I the tire place I use picked up on them being a bit worn... I was considering changing them along with my rear pads as they need doing too, but if it's a big job then I'll get my garage to do it!
Also do the j spec rear calipers require a caliper rewind tool when replacing the pads?
You'll need to replace the complete upper arm as the bushes aren't sold separately. Straight forward job to replace, any competent garage should be fine. Get the geometry checked/set at the same time. See workshop manual HERE
Toyota part numbers
48770-19025 Rear Upper Arm - RH
48790-19025 Rear Upper Arm - LH
