TLicense Posted May 24, 2010 Share Posted May 24, 2010 job done wow that clip and spring are a right pain in the arse well its done now, cheers to all for your input i needed it just one thing tho the little thing at the 6 o`clock position didnt make and clicking noises when whineding back the shoes, how do i reset the hand brake once wound back ? look through one of the holes in the hub and you should find it will line up with the adjuster. Now with a screw driver rotate it and thats how you you adjust it. You shouldn't have to belt the disc off as you'll bend the pins, as you've found out. When you come to re-fitting the disc, spin the little spindle that's at the 6 oclock position to pull the handbrake shoes in a little bit. Then fit the disc. You then need to spin the spindle the opposite direction to before to push the shoes back out untill they touch the disc. To do this, spin the disc around until one of the holes lined up with where the spindle is (In your first pic, it's the one with the rubber bung in) You should then be able to reach in with a flat bladed screwdriver and turn the spindle. Do a click on the spindle and then try spinning the disc - it'll be loose and then it'll bind up completely. Once you've got the disc locked up, unwind the spindle 8 clicks so it doesn't bind up as you're driving. Job done. It's like I'm talking, but there's nobody listening! Quote Link to comment Share on other sites More sharing options...
supra steveo Posted May 24, 2010 Author Share Posted May 24, 2010 You going to put mine back together then? yeah but i need to order your new part first dont i or did you just want it left off so you can put it on the aerotop ??? Quote Link to comment Share on other sites More sharing options...
supra steveo Posted May 24, 2010 Author Share Posted May 24, 2010 no mate , i heard you and sorted it cheers Quote Link to comment Share on other sites More sharing options...
pedrosixfour Posted May 24, 2010 Share Posted May 24, 2010 You going to put mine back together then? Brave man. Quote Link to comment Share on other sites More sharing options...
supra steveo Posted May 24, 2010 Author Share Posted May 24, 2010 Brave man. lol am a jap spec brake ninja now man could probs do it with my eyes closed, any way its not that hard Quote Link to comment Share on other sites More sharing options...
pedrosixfour Posted May 24, 2010 Share Posted May 24, 2010 Well the confidence is certainly there. And sure we all know there is only ever about 2% skill involved. So I guess you really do have the credentials! Quote Link to comment Share on other sites More sharing options...
Dnk Posted May 24, 2010 Share Posted May 24, 2010 2% skill, 98% big hammer hmmmm think i'll do mine the old fashioned way with tlc and latex gloves Quote Link to comment Share on other sites More sharing options...
Al Massey Posted May 24, 2010 Share Posted May 24, 2010 yeah but i need to order your new part first dont i Good point, oh and you might aswell order the aerotop bolt too:d since you stole mine Ill be stripping the hardtop down soon completley and getting rid of the shell so there will be more space in my HAS if you need to put your car up there Quote Link to comment Share on other sites More sharing options...
supra steveo Posted May 24, 2010 Author Share Posted May 24, 2010 Good point, oh and you might aswell order the aerotop bolt too:d since you stole mine Ill be stripping the hardtop down soon completley and getting rid of the shell so there will be more space in my HAS if you need to put your car up there stole ?? borrowed Quote Link to comment Share on other sites More sharing options...
