jackso11 Posted May 21, 2010 Share Posted May 21, 2010 Looking to get my probe fitted in the manifold, but is it wise? I know it gives the best results but I have read it can take out a turbo.....does that happen much? and is it only if you are thrashing it? Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted May 21, 2010 Share Posted May 21, 2010 I would have thought that if an EGT probe fails, it is either very poor quality, or the temps are high enough to cause det or damage anyway. Quote Link to comment Share on other sites More sharing options...
jackso11 Posted May 21, 2010 Author Share Posted May 21, 2010 Thats what I would have thought but I remember reading a few posts on here about the sensor going and taking out a turbo, wondered if it is common or a freak occurance. Quote Link to comment Share on other sites More sharing options...
Robzki Posted May 21, 2010 Share Posted May 21, 2010 I'm considering fitting mine in the manifold too. conflicting info that if its in the 1st decat its useless and if its in the manifold you run a high risk of knackering the turbos....... Quote Link to comment Share on other sites More sharing options...
heckler Posted May 21, 2010 Share Posted May 21, 2010 i've had my probe mounted on exhaust manifold for 5 years - 3 years on stock manifold, 2 years on the current cast manifold. No problems here Quote Link to comment Share on other sites More sharing options...
Branners Posted May 21, 2010 Share Posted May 21, 2010 I think Foodfreak had his EGT probe fail and make its way in a disorderly fashion through his turbo. It does happen, anything that sits in 900degree heat is going to be prone to failure. One viewpoint is that it is cheaper to lose a turbo than a whole engine, the other viewpoint is that if you can subtract 150degrees from whatever reading you get then you would PROBABLY be safe. More accurate readings pre-turbo, no chance of it going through the turbo if post turbo, but more chance of the engine going down due to det. Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted May 21, 2010 Share Posted May 21, 2010 There is the alternative of placing the sensor in the turbo exhaust housing, that way you get a fairly realistic EGT, and stand a lot less chance of it damaging the inducer, as it should go straight out the exhaust should the worst happen;) Quote Link to comment Share on other sites More sharing options...
foodfreak Posted May 22, 2010 Share Posted May 22, 2010 JB's right........ I had a greddy probe break up, took out my 1st turbo when I was on twins. I know that Leon & Terry Saunders both had probes break & bugger the turbo. all probes were situated in the runners. I haven't bothered with an egt since Quote Link to comment Share on other sites More sharing options...
jevansio Posted May 22, 2010 Share Posted May 22, 2010 My sesnor is in the turbo exh housing, I see temps of 925-950. I'm told that the temps in the housing are hotter in the runner even though it is farther from the engine (due to the extra heat generated from 6 flows merging and a continuous flow rather than an interrupted single flow in one of the runners), don't know how much truth there is in that & I'd only find out if I moved a probe into a runner to know for sure. I used to have my probe in the downpipe & saw a +200 deg change when I moved it into the housing Quote Link to comment Share on other sites More sharing options...
JamieP Posted May 22, 2010 Share Posted May 22, 2010 Mine has been fine for about 20k in runner six, egt's max at about 900c Quote Link to comment Share on other sites More sharing options...
jackso11 Posted May 22, 2010 Author Share Posted May 22, 2010 i've had my probe mounted on exhaust manifold for 5 years - 3 years on stock manifold, 2 years on the current cast manifold. No problems here Whereabouts in the manifold? I heard 1st runner is the easiest place to put it as you can reach it from the top without much bother? Quote Link to comment Share on other sites More sharing options...
Terminator Posted May 22, 2010 Share Posted May 22, 2010 (edited) My probe was in runner one for 6+years it is now in runner 6 1 year. I rarely see EGT's above high 800's. My take same as John's, I would rather protect my engine than my turbo. I remember having nagging doubts about fitting it to runner one when first fitted, but after a while, I realised the possibility of it causing damage was very slight. Unless you are seeing 900+ degree on a very regular basis I would not worry about it. When you consider all the things that could go wrong, in a high performance motor, it puts it into perspective. I think the perception that EGT's fail regularly is completely wrong, given the number in use, the % failure rate is very low. When one does go, who knows if the probe was at fault, there are many other factors that could have caused it, no one has the time, money or facilities to establish the true cause, at best all blame is conjecture. Edited May 22, 2010 by Terminator (see edit history) Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted May 22, 2010 Share Posted May 22, 2010 If you buy the right type of probe it won't melt. You need an Inconel one. I sell them, but they aren't cheap. Quote Link to comment Share on other sites More sharing options...
TLicense Posted May 22, 2010 Share Posted May 22, 2010 This'll see you well... http://www.cosworth.com/Default.aspx?id=1099651 Quote Link to comment Share on other sites More sharing options...
jackso11 Posted May 24, 2010 Author Share Posted May 24, 2010 who can fit this in the runner? I did ask you for a quote Chris....then I realised you live a long way from london Paul Whiffin doesn't fit them in the manifold. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted May 24, 2010 Share Posted May 24, 2010 Yes, I fit them in the front cylinder runner on stock TT manifolds. You would have to weld in a threaded boss on tubular manifolds, otherwise the adaptor will only be held by about a thread and a half, due to the tube's thin wall thickness. Quote Link to comment Share on other sites More sharing options...
Ian C Posted May 24, 2010 Share Posted May 24, 2010 I used to have a GReddy one in the front runner, installed by CW himself When going from twins to big single, I decided to hedge my bets and put it in the tubular manifold's collector, biased towards the wastegate pipe. So I get the pre-turbo temperature reading, but if it fractures chances are it's exiting through the wastegate and doing no damage. It's been there for years but then I don't drive it much these days. Don't really see past 850deg on full chat, for what its worth. Quote Link to comment Share on other sites More sharing options...
jackso11 Posted June 3, 2010 Author Share Posted June 3, 2010 I still need to get this fitted. My EGT guage arrived this morning so want to get it in now CW, why are you so far away! I am in east london, shorpshire is quite a drive awaw Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted June 3, 2010 Share Posted June 3, 2010 No where is really far away from anywhere else in the UK, ask Americans who regularly drive 200 miles for a decent nosh What's really the problem is you southerners are afraid of us savages "oop north" Quote Link to comment Share on other sites More sharing options...
jackso11 Posted June 3, 2010 Author Share Posted June 3, 2010 Haha, I'm a Lincolnshire lad mate, further north than you! only down here for the city life. I know its not that far but with the price of petrol these days its pretty expensive to drive up to you just to get an EGT probe fitted. Maybe I can think of some other things you could do at the same time. haha Quote Link to comment Share on other sites More sharing options...
Nodalmighty Posted June 3, 2010 Share Posted June 3, 2010 You can buy 3mm Inconel 600 K types for about £15 each. I built a 8 channel reader logger for an MR2 chap using my own EGT amps. He used Race Tech ones which I think are £25 with the gland but I have a feeling they are stainless steel. You can use SS if it's just for short duration dyno work, but like Chris says, Inconel is best for long duration use. http://www.tcdirect.co.uk/deptprod.asp?deptid=190/1#0 150mm is a bit long but you want the tip in the centre of the pipe so not to much sticks out and they can be bend in a quite tight radius. Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted June 3, 2010 Share Posted June 3, 2010 Haha, I'm a Lincolnshire lad mate, further north than you! only down here for the city life. I know its not that far but with the price of petrol these days its pretty expensive to drive up to you just to get an EGT probe fitted. Maybe I can think of some other things you could do at the same time. haha LOL! just wait until he tell you how much to get the sensor fitted:p Why not ask AFR to do it, only 60-70 mls away. Quote Link to comment Share on other sites More sharing options...
