Guest jackfrosty Posted May 21, 2010 Share Posted May 21, 2010 My Mk4 Supra has a squeaking clutch. Not a squeak from the pedal going up and down, but a constant twittering squeak in time with the engine revs. Depressing the clutch pedal slightly makes the sound go away. Is it the thrust bearing? Is it a problem that must be fixed or is it just an annoying noise? How hard a job is it to replace? Thanks Quote Link to comment Share on other sites More sharing options...
trinitom Posted May 21, 2010 Share Posted May 21, 2010 My Mk4 Supra has a squeaking clutch. Not a squeak from the pedal going up and down, but a constant twittering squeak in time with the engine revs. Depressing the clutch pedal slightly makes the sound go away. Is it the thrust bearing? Is it a problem that must be fixed or is it just an annoying noise? How hard a job is it to replace? Thanks that's probably the release bearing, only way to replace is removing the gearbox. mine is doing the same for at least 1 year and no problems, apart from the annoying noise. Quote Link to comment Share on other sites More sharing options...
Neil-NA Posted May 21, 2010 Share Posted May 21, 2010 Mines done the same since i got the car last September. Finally got round to buying a new clutch with release bearing. It has to be said it is a bloody annoying sound. Quote Link to comment Share on other sites More sharing options...
Guest jackfrosty Posted May 21, 2010 Share Posted May 21, 2010 Ok cheers, guess I'll just put up with it then. Yes it is most annoying. Quote Link to comment Share on other sites More sharing options...
