sams Posted May 20, 2010 Share Posted May 20, 2010 (edited) I just removed my radiator as i had a bird decide to fly throught it, when i removed the two smaller pipes on the bottom of the rad red oils came from them, but niether my trans or steering fluid levels droped. So what was the oil? Also while im at it im going to fit a fmic(smic is seen better days) What would i need to do to my car after the fmic is fitted? i have a set of iridum plugs with a service pack i have. The car is stock at the min, it a 94 tt jspec. Edited May 20, 2010 by sams (see edit history) Quote Link to comment Share on other sites More sharing options...
David P Posted May 20, 2010 Share Posted May 20, 2010 That's the autobox oil cooler. Quote Link to comment Share on other sites More sharing options...
sams Posted May 20, 2010 Author Share Posted May 20, 2010 So where does it top up, i assume i top up the autobox when i run her again Quote Link to comment Share on other sites More sharing options...
bluecoup Posted May 20, 2010 Share Posted May 20, 2010 i didn't when i changed mine as it was a top mark before and the oil coller seemed to hold such little oil just check it on run up after while checking it over for water leaks Quote Link to comment Share on other sites More sharing options...
sams Posted May 20, 2010 Author Share Posted May 20, 2010 Ok cheers can anyone advise on the fmic? Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted May 20, 2010 Share Posted May 20, 2010 You wouldnt need to do anything to your car after fitting a front mount, depending on the quality of the kit depends on how much of a ball buster it is to fit. Get a stock sidemount, more than adequate Dont forget to check your auto box oil with the engine running Quote Link to comment Share on other sites More sharing options...
