fabiocandido Posted May 20, 2010 Share Posted May 20, 2010 hello an electrician friend of mine came to check my car as i have a few problems with the lights, i need to find the location for the Body control module. any suggestions??? looks like there is the problem. thanks Quote Link to comment Share on other sites More sharing options...
heckler Posted May 20, 2010 Share Posted May 20, 2010 hello an electrician friend of mine came to check my car as i have a few problems with the lights, i need to find the location for the Body control module. any suggestions??? looks like there is the problem. thanks Body Control Module? Quote Link to comment Share on other sites More sharing options...
fabiocandido Posted May 20, 2010 Author Share Posted May 20, 2010 :search:yeah Quote Link to comment Share on other sites More sharing options...
heckler Posted May 20, 2010 Share Posted May 20, 2010 :search:yeah never heard of one... Quote Link to comment Share on other sites More sharing options...
supracars Posted May 20, 2010 Share Posted May 20, 2010 huh?? Quote Link to comment Share on other sites More sharing options...
SupraD06 Posted May 20, 2010 Share Posted May 20, 2010 Taken from google What is Body Control Module (BCM)? A component of self-diagnostic systems used to control vehicle function based on monitored inputs. The body control module is a computer that controls the body functions on a car. It usually controls the lights and locks and such. Quote Link to comment Share on other sites More sharing options...
fabiocandido Posted May 21, 2010 Author Share Posted May 21, 2010 ok guys, thanks a lot. so there is no body control module on the supra... after some research i found all the modules in the car. -aerial control module -air conditioning " -airbag " -bulb failure warning " (thats the one) -c/locking " -cruise control " -differential oil cooler " -engine " -front spoiler " -fuel pump " -power stering " -traction control " -heater function " just in case someone needs to know:D Quote Link to comment Share on other sites More sharing options...
trinitom Posted May 21, 2010 Share Posted May 21, 2010 the bulb failure warning is located on the rear passenger panel, behind the boot light. it only operate the rear lights. if you have problems with the rear light's that's the box you need to check. Quote Link to comment Share on other sites More sharing options...
fabiocandido Posted May 25, 2010 Author Share Posted May 25, 2010 the bulb failure warning is located on the rear passenger panel, behind the boot light. it only operate the rear lights. if you have problems with the rear light's that's the box you need to check. thanks mate,problem solved! Quote Link to comment Share on other sites More sharing options...
