n/a induction pipe
Dave
thanks barney ,if im gonna fit an ally pipe into the 75mm silicon what size should that be ??
what i want to achieve is silicon pipe from the throttle body then 90 degree ally pipe then silicon connector pipe onto my apexi hardpipe
i think the hard pipe you have should be 75mm aswell ,so get a 75mm 90 degree bend.
I used 76mm for mine. got a 90 bend 6inch by 6 inch had to cut 2inch off to get it to clear my shrut brace, two 76mm sil hoses then a 6 inch by 6 inch 45 bend to my air filter then heat wrapped the lot (i would add a pic but me and computers :sly:) itcost me less than £40.
Edited by Mcvites69
missed a bit (see edit history)
  • 3 weeks later...
