Help with Apex S-AFC install!
randy
I am in the process of installing the Apex -S-AFC soon and I need some help with install instructions to my jap spec. According to the instructions from Apex they ask you to connect it to pin 62 which is the Turbo pressure sensor output wire.
But I have already used this for the install of the Greddy BCC. Now the U.S spec cars have MAF sensor so have hooked it up to pin 66 which is the Mass Air Flow sensor.
Im not sure which applies to our jap spec as we dont use a MAF sensor?
Which pin do you hook it to and what do you do about the BCC which is
hooked to pin 62 {turbo pressure sensor}?
Please help.:conf:
This is the 2nd time you've questioned the A'pexi instructions!
They are correct.
You use the same wire that the bcc uses . It just has to go thro' either the FC or the BCC first.
Theres a thread a lil further down the page that discusses which should go first.......
I am confused about this as I have heard too many different views?:conf: Also I am using the Greddy BCC not the FCD. Ok considering we connect it to the Turbo Pressure Sensor pin62.
Do I connect the AFC before the BCC wire going to the ECU or after the BCC wire going to the ECU?:thumbs:
