2003 mini one power steering failure???
Guest daz 6576
Guest daz 6576
power steering turning on and off and is becoming more regular by the look of it, does anyone know any info on this problem with mini's.
cheers daz
Yes its a common problem - Stop using the car now !
the failure gets worse and end up that you cannot turn off the power steering pump - so you end up with a flat battery and the loom to the power steering pump melts ,add another £75
Remove the pump , strip and clean out all the carbon build up , reassemble and refit - if done early enough it will cure the problem ,if not a new pump is needed circa £300
clean the pump every couple of years , the latest pumps also fail but less than the early ones
