dani_r Posted May 18, 2010 Share Posted May 18, 2010 My HKS SSQV arrived today - chuffed! Fitted HKS SSQV - chuffed! Test drove car with HKS SSQV - Disappointed at the poor noise Drove home and started to tinker with the pipes and adjuster bolt at the back and then the vacuum hose connector snaps right off the SSQV right at the join! - Fully fully p*ssed off Can someone please tell me if that bit can be replaced? Surely the whole unit isn't a write-off? Cheers Dan Link to comment Share on other sites More sharing options...
Ric Posted May 18, 2010 Share Posted May 18, 2010 you probably bought an ebay fake Link to comment Share on other sites More sharing options...
bradleyh_15 Posted May 18, 2010 Share Posted May 18, 2010 picks? Link to comment Share on other sites More sharing options...
dani_r Posted May 18, 2010 Author Share Posted May 18, 2010 It's the BOV I bought from Ellis in this thread http://www.mkivsupra.net/vbb/showthread.php?t=216943 It's broken right at the point where the vacuum pipe would go onto the BOV Also, it looks totally different to the other SSQVs that you see. Is it an older unit? Link to comment Share on other sites More sharing options...
dani_r Posted May 18, 2010 Author Share Posted May 18, 2010 This is where it broke Link to comment Share on other sites More sharing options...
RobD Posted May 18, 2010 Share Posted May 18, 2010 Could try gluing it but would have to be super careful not to block up the tube itself with glue! Link to comment Share on other sites More sharing options...
nevins Posted May 18, 2010 Share Posted May 18, 2010 look for a scrap one , and replace the top section mate. Link to comment Share on other sites More sharing options...
dani_r Posted May 18, 2010 Author Share Posted May 18, 2010 Can I just unbolt the millions of tiny nuts and replace it? Link to comment Share on other sites More sharing options...
Lee P Posted May 18, 2010 Share Posted May 18, 2010 It woudnt just break, the early versions like you have there are more robust than the new ones. Its more likely that its been bent before and one tug in the opposite direction just broke it. Link to comment Share on other sites More sharing options...
bradleyh_15 Posted May 18, 2010 Share Posted May 18, 2010 look for a scrap one , and replace the top section mate. that or find a very good fabricator! Link to comment Share on other sites More sharing options...
SUPRALOOPY Posted May 18, 2010 Share Posted May 18, 2010 It slides out (the metal bit) if it won't come out get a drill bit the right size and drill it out and push the bit you have into the hole. use a bit of superglue to seal and job done.. (don't see what all the fuss is about..lol) Link to comment Share on other sites More sharing options...
nevins Posted May 18, 2010 Share Posted May 18, 2010 Cant see a problem with taking it apart mate, iv stripped them before to clean them out Link to comment Share on other sites More sharing options...
mwilkinson Posted May 18, 2010 Share Posted May 18, 2010 It's the BOV I bought from Ellis in this thread http://www.mkivsupra.net/vbb/showthread.php?t=216943 It's broken right at the point where the vacuum pipe would go onto the BOV Also, it looks totally different to the other SSQVs that you see. Is it an older unit? Yeah that looks like the old model. I have one of these and it does not have the adjuster at the rear and the colour is different. Link to comment Share on other sites More sharing options...
a98pmalcolm Posted May 18, 2010 Share Posted May 18, 2010 to mate it louder u wanna unscrew the bolt that will loosen the spring Link to comment Share on other sites More sharing options...
dani_r Posted May 18, 2010 Author Share Posted May 18, 2010 to mate it louder u wanna unscrew the bolt that will loosen the spring Is that done by losening the 10mm bolt at the back? Link to comment Share on other sites More sharing options...
pistonbroke Posted May 18, 2010 Share Posted May 18, 2010 I didn't think the ssqv2 was adjustable? Link to comment Share on other sites More sharing options...
ellis Posted May 18, 2010 Share Posted May 18, 2010 Can't believe this Dan! Been on my car for over a year with no problems. Sounds like an easy fix though. eBay fake? Cheeky sod!! Link to comment Share on other sites More sharing options...
Darragh Posted May 18, 2010 Share Posted May 18, 2010 It slides out (the metal bit) if it won't come out get a drill bit the right size and drill it out and push the bit you have into the hole. use a bit of superglue to seal and job done.. (don't see what all the fuss is about..lol) I had a fake eBay one it worked well u til I broke the same bit lol as said above I done this with a drill and it lasted another five months till I got myself the real deal Link to comment Share on other sites More sharing options...
Homer Posted May 18, 2010 Share Posted May 18, 2010 As mentioned about, the tube can be replaced, but the BOV needs to be disasembled to do it. The pic looks like a genuine one, it's even discoloured the same way the genuine ones do Not heard of this happening before though. Link to comment Share on other sites More sharing options...
RobUK Posted May 18, 2010 Share Posted May 18, 2010 I have one thats broken if you need the replacement needle part.... Rob Link to comment Share on other sites More sharing options...
dani_r Posted May 18, 2010 Author Share Posted May 18, 2010 to mate it louder u wanna unscrew the bolt that will loosen the spring I have one thats broken if you need the replacement needle part.... Rob Really!? Excellent! You have a PM Link to comment Share on other sites More sharing options...
dani_r Posted May 18, 2010 Author Share Posted May 18, 2010 Can't believe this Dan! Been on my car for over a year with no problems. Sounds like an easy fix though. eBay fake? Cheeky sod!! No worries matey It was my own stupid fault! RobUK has a spare unit so it looks like we'll be back on the road soon Is the stock unit working ok for you? Link to comment Share on other sites More sharing options...
a98pmalcolm Posted May 18, 2010 Share Posted May 18, 2010 Is that done by losening the 10mm bolt at the back? yer thats correct mate the 10 mm bolt. By screwing it in will make the spring stifer. unscrew it and it should be louder (or to wooooosh and lower boost levels) The new ones dont have the screw they are pre set for individual cars. Link to comment Share on other sites More sharing options...
dani_r Posted May 19, 2010 Author Share Posted May 19, 2010 yer thats correct mate the 10 mm bolt. By screwing it in will make the spring stifer. unscrew it and it should be louder (or to wooooosh and lower boost levels) The new ones dont have the screw they are pre set for individual cars. Spot on Cheers mate. I'll have a play around when I get the tube sorted Link to comment Share on other sites More sharing options...
a98pmalcolm Posted May 19, 2010 Share Posted May 19, 2010 no worrys mate. good luck with it and i hope all ends well with it Link to comment Share on other sites More sharing options...
