Nodalmighty Posted May 20, 2010 Author Share Posted May 20, 2010 "MOTOR SPORT" prices, don't you just love 'um. Lyndon. Link to comment Share on other sites More sharing options...
Nodalmighty Posted May 20, 2010 Author Share Posted May 20, 2010 Saw this all first hand yesterday at Lyndons and i can see these selling nicely. Be like a Powerfc commandor but with 10 times the functions! Good work sir! Thank you sir, The two digital IO channels can also drive 0-5v analogue so we can use them to drive the Syvecs Traction Control and MAP table selection pins rather than separate twisty knobs. Lyndon. Link to comment Share on other sites More sharing options...
JamieP Posted May 20, 2010 Share Posted May 20, 2010 Sounds good, will talk with Ryan about it when i see him so he can explain it in bricklayer terms:d Link to comment Share on other sites More sharing options...
GlennK Posted May 20, 2010 Share Posted May 20, 2010 For clarity - The unit can display 4 data streams at once e.g. EGT, Oil Pressure, Oil Temp, Water temp? If so - stunning! Link to comment Share on other sites More sharing options...
Nodalmighty Posted May 20, 2010 Author Share Posted May 20, 2010 For clarity - The unit can display 4 data streams at once e.g. EGT, Oil Pressure, Oil Temp, Water temp? If so - stunning! It could display 16 in text mode. But basically you can plug 3 screens in the base unit which talks to the syvecs and select what each one displays so it could display 48 streams over 3 screens theoretically. It can do dyno pull style graphs between rpms, Data logger style continuous graphs. I will most likely add a performance timer so you can practice the 0-60, 0-100, 1/8, 1/4 and standing mile etc. etc. There will also be a multi channel EGT for individual cylinder logging. This will give you an idea of the fuel distribution across cylinders and also any gradual injector disparity over time. On a Supra the remaining two channels could log temp across the inter cooler for efficientcy. I can make it do most things memory/my time to code it permitting. Lyndon. Link to comment Share on other sites More sharing options...
Swampy442 Posted May 20, 2010 Share Posted May 20, 2010 An amazing bit of kit. Kudos to you mate Link to comment Share on other sites More sharing options...
caseys Posted July 18, 2010 Share Posted July 18, 2010 PM'd you, how's the progress going on these? Link to comment Share on other sites More sharing options...
NOS Posted July 18, 2010 Share Posted July 18, 2010 End of August is when they will be ready. Link to comment Share on other sites More sharing options...
Nodalmighty Posted July 19, 2010 Author Share Posted July 19, 2010 I have applied for a hobbiest trader account. Should I be successful and granted one I will post up prices and a proper write up. The first few prototypes will be ready for end of August/ Beginning of September. The screens will be a production item but the base computer will still be based on Vero board and flying leads rather than PCB and PCB mounted RJ45 and RJ11 sockets for the screens. The ZIF based wiring system plug will be available on both as will the optional Syvecs connectivity. I'm currently doing one for a member on here into a 2 gauge pillar pod, so I should have pictures of that soon. Link to comment Share on other sites More sharing options...
caseys Posted July 19, 2010 Share Posted July 19, 2010 Happy to be a tester of this. Thanks for the information and watching this very keenly. Link to comment Share on other sites More sharing options...
GlennK Posted July 19, 2010 Share Posted July 19, 2010 Hi Lyndon, as an early tester of your gauges I'm happy to support your application. Let me know when they're ready. Cheers. Link to comment Share on other sites More sharing options...
Nodalmighty Posted July 20, 2010 Author Share Posted July 20, 2010 Hi Lyndon, as an early tester of your gauges I'm happy to support your application. Let me know when they're ready. Cheers. Will do. Pressure Sensors should be with me by the end of the week. Once I have these I can do the calibration curves for all the sensors. I have also modified an earlier prototype screen (pre billet) to have the warning LED and that works a treat. Ryan came good with the replacement Syvecs before he went to Oz so I can also crack on with the Serial stream decoder too. Link to comment Share on other sites More sharing options...
creative Posted July 20, 2010 Share Posted July 20, 2010 I understand non of what you have said...... but it sounds impressive! fancy sending one to oz for my ute! Link to comment Share on other sites More sharing options...
Nodalmighty Posted July 20, 2010 Author Share Posted July 20, 2010 I understand non of what you have said...... but it sounds impressive! fancy sending one to oz for my ute! What do you want it to display and what ecu does it run? Link to comment Share on other sites More sharing options...
creative Posted July 20, 2010 Share Posted July 20, 2010 What do you want it to display and what ecu does it run? I have no idea! lol.... Its a standard ecu tho but is a V8! Link to comment Share on other sites More sharing options...
Nodalmighty Posted September 3, 2010 Author Share Posted September 3, 2010 It would appear that the mono LCD modules have a serious white out in direct sunlight. Bit of a bugger since I designed the billet housing around these . However, I've decides Mono is gash and I'm going to go with OLED 65k colour, with nearly double the resolution, 2gb on board micro SD card and real time GFX processor. Fortunately these are the same size module (well smaller actually but the same visible area (This means I can do a proper 60mm gauge (I maybe able to do a 52mm one too as there is a smaller sister module). The other change is these will be ECU units only. Now Link have finally released the data stream spec I can support the 3 main Supra ecu's Syvec, AEM and Link G4 (or G3 with G4 firmware upgraded Ed ) Apologise to GlennK who is my first customer. I'm working out a short term solution for him going forward prior to going OLED. Link to comment Share on other sites More sharing options...
Swampy442 Posted September 3, 2010 Share Posted September 3, 2010 No support for the Fcon? Link to comment Share on other sites More sharing options...
Nodalmighty Posted September 3, 2010 Author Share Posted September 3, 2010 No support for the Fcon? I know nothing about the F-Con. If it has a serial D-stream and documentation I can support it. Link to comment Share on other sites More sharing options...
EdMorris Posted September 5, 2010 Share Posted September 5, 2010 It would appear that the mono LCD modules have a serious white out in direct sunlight. Bit of a bugger since I designed the billet housing around these . However, I've decides Mono is gash and I'm going to go with OLED 65k colour, with nearly double the resolution, 2gb on board micro SD card and real time GFX processor. Fortunately these are the same size module (well smaller actually but the same visible area (This means I can do a proper 60mm gauge (I maybe able to do a 52mm one too as there is a smaller sister module). The other change is these will be ECU units only. Now Link have finally released the data stream spec I can support the 3 main Supra ecu's Syvec, AEM and Link G4 (or G3 with G4 firmware upgraded Ed ) Apologise to GlennK who is my first customer. I'm working out a short term solution for him going forward prior to going OLED. Sounds interesting, but I need to get the bloody thing driving first. Link to comment Share on other sites More sharing options...
GlennK Posted September 5, 2010 Share Posted September 5, 2010 Ryan's installing the S6 on Monday (6th) and will wire in the 4 sensors (EGT, Oil Temp & Pressure, Auto Fluid Temp). Then Tuesday will start the mapping process. Hopefully Lyndon will have the interim LCD solution soon. Fingers crossed! Link to comment Share on other sites More sharing options...
Nodalmighty Posted September 7, 2010 Author Share Posted September 7, 2010 Glenn, Hope the sensors arrived OK. Here is a link to the pinout for the pressure sensor : http://www.aisensors.com/PressureDataSheets/PT9.pdf I have now cracked the data stream on the Syvecs and got my unit talking to it and displaying stuff. Link to comment Share on other sites More sharing options...
GlennK Posted September 7, 2010 Share Posted September 7, 2010 Great news, Lyndon - Paul W confirmed the sensors have arrived today. The pinout is to hook up the sensor to the S6, right? Link to comment Share on other sites More sharing options...
Nodalmighty Posted September 7, 2010 Author Share Posted September 7, 2010 Great news, Lyndon - Paul W confirmed the sensors have arrived today. The pinout is to hook up the sensor to the S6, right? Yeah! Sensor Gnd, 5v and signal out( 0.5v = 0 , 4.5v = 10 bar) Link to comment Share on other sites More sharing options...
Wez Posted September 7, 2010 Share Posted September 7, 2010 Are you talking can bus or serial to the S6? Link to comment Share on other sites More sharing options...
Nodalmighty Posted September 7, 2010 Author Share Posted September 7, 2010 Are you talking can bus or serial to the S6? Only Serial at the moment, but that gives plenty of info. Link to comment Share on other sites More sharing options...
