Guest Budz86 Posted May 16, 2010 Share Posted May 16, 2010 As tittle really. My NA has a 110 mph speedo in it, but looking to change it for something with more numbers! Firstly, I take it they are plug and play? Also, is there anything else I need to consider? Edit: Also, I'm possibly on the look out for a new boot carpet as mine is filthy! Link to comment Share on other sites More sharing options...
supra steveo Posted May 16, 2010 Share Posted May 16, 2010 they aint plug and play mate, you need a TSD that will convert KMH into MPH (well if i am right ) then you will need to source a new dial face ........... ever looked into the el-glo dials ? Link to comment Share on other sites More sharing options...
Guest Budz86 Posted May 16, 2010 Share Posted May 16, 2010 I've got a Thor de-relimiter already, and my current speedo reads in MPH, but the dial only goes to 110. I forgot about the el-glo's tbh, but I still want a fairly stock look inside so not sure if they will be the best choice Link to comment Share on other sites More sharing options...
Guest Budz86 Posted May 18, 2010 Share Posted May 18, 2010 Bumpski! Link to comment Share on other sites More sharing options...
supra steveo Posted May 18, 2010 Share Posted May 18, 2010 reverse-glo?? can get them in what ever speed set up you want too Link to comment Share on other sites More sharing options...
RobD Posted May 18, 2010 Share Posted May 18, 2010 All you have to do is take the facia off the speedo! You should have the 180kph dial underneath! Link to comment Share on other sites More sharing options...
evinX Posted May 18, 2010 Share Posted May 18, 2010 Just get a ebay facia, with the km/h and mph on it...if you want more numbers youll have to delimit and all that stuff Link to comment Share on other sites More sharing options...
RobD Posted May 18, 2010 Share Posted May 18, 2010 If he's got the convertor he shouldn't need anything! The 110mph dial he has is a facia on top of a facia, remove this and fit the convertor he should have a 180 speedo Link to comment Share on other sites More sharing options...
pistonbroke Posted May 18, 2010 Share Posted May 18, 2010 Enough numbers for you? Look better than stock IMHO. Link to comment Share on other sites More sharing options...
RobUK Posted May 18, 2010 Share Posted May 18, 2010 If you are interested..... http://www.mkivsupra.net/vbb/showthread.php?t=216259 Link to comment Share on other sites More sharing options...
Guest Budz86 Posted May 18, 2010 Share Posted May 18, 2010 Those dials are Tom, where did you get them? Although it's an NA, no need for the 220 mph! Overkill I think! Link to comment Share on other sites More sharing options...
Guest Budz86 Posted May 18, 2010 Share Posted May 18, 2010 Still not sure what you mean Rob? Speedo was originally (I presume) in KPH, but it now has a MPH face and reads in MPH. If I take the MPH face off, surely the readout on the KPH will then be wrong, unless there's a way to re-calibrate? Link to comment Share on other sites More sharing options...
pistonbroke Posted May 19, 2010 Share Posted May 19, 2010 they are reverse el-glo. you can get them that only go to 180mph if thats what you want. You can get them from the group buys that go on here regularly. They change colour too, they switch to green if you prefer. Link to comment Share on other sites More sharing options...
RobD Posted May 19, 2010 Share Posted May 19, 2010 If you have a Thor delimiter I'd imagine you've got a speedo convertor just not wired up! Locate the Thor delimiter and see if there's any extra wires coming out of it! Link to comment Share on other sites More sharing options...
Guest Budz86 Posted May 19, 2010 Share Posted May 19, 2010 Tom - Nice one, I've seen the GB's run, but never bothered getting in on the action. Rob - Thanks mate, I'll have to give Matt at AFR a call and see where he's hidden it! Link to comment Share on other sites More sharing options...
supra steveo Posted May 19, 2010 Share Posted May 19, 2010 Those dials are Tom, where did you get them? Although it's an NA, no need for the 220 mph! Overkill I think! El-glo GB that I organize......... AND you can tell me exactly what you want the dials to look like Link to comment Share on other sites More sharing options...
pistonbroke Posted May 19, 2010 Share Posted May 19, 2010 Who's Tom?.......I'm Dan Link to comment Share on other sites More sharing options...
Guest Budz86 Posted May 19, 2010 Share Posted May 19, 2010 Who's Tom?.......I'm Dan Sorry mate! Tom sounds much better anyway Bit like Rodney being called Dave! Link to comment Share on other sites More sharing options...
pistonbroke Posted May 19, 2010 Share Posted May 19, 2010 Cheers trig Link to comment Share on other sites More sharing options...
Guest Budz86 Posted May 19, 2010 Share Posted May 19, 2010 Link to comment Share on other sites More sharing options...
