Speedo to replace the stock 110mph JDM version
Guest Budz86
Guest Budz86
As tittle really. My NA has a 110 mph speedo in it, but looking to change it for something with more numbers! :eyebrows:
Firstly, I take it they are plug and play? Also, is there anything else I need to consider?
Edit: Also, I'm possibly on the look out for a new boot carpet as mine is filthy!
Guest Budz86
I've got a Thor de-relimiter already, and my current speedo reads in MPH, but the dial only goes to 110.
I forgot about the el-glo's tbh, but I still want a fairly stock look inside so not sure if they will be the best choice
Guest Budz86
Those dials are :cool: Tom, where did you get them? Although it's an NA, no need for the 220 mph! Overkill I think! :D
Guest Budz86
Still not sure what you mean Rob? Speedo was originally (I presume) in KPH, but it now has a MPH face and reads in MPH. If I take the MPH face off, surely the readout on the KPH will then be wrong, unless there's a way to re-calibrate?
Guest Budz86
Tom - Nice one, I've seen the GB's run, but never bothered getting in on the action.
Rob - Thanks mate, I'll have to give Matt at AFR a call and see where he's hidden it!
Guest Budz86
Who's Tom?.......I'm Dan :D
Sorry mate! :innocent: Tom sounds much better anyway :D
Bit like Rodney being called Dave!
