francis Posted May 27, 2005 Share Posted May 27, 2005 Hi there Just bought Nick's UK 6spd TT and have been driving it almost contantly for the last two days! Anyway I've noticed sometimes it juts won't go in to sixth gear, and then at other times it seems to go in fine. Is there something I'm missing, does it matter what speed you're travelling at to put it in sixth or is this a common problem? Cheers, Francis Link to comment Share on other sites More sharing options...
nickyboy Posted May 27, 2005 Share Posted May 27, 2005 Mate, I never had any probs at all going into 6th - it's in a different position to 5th that 4th is from 2nd and that 3rd is from 1st so it takes a bit of getting used to... Link to comment Share on other sites More sharing options...
francis Posted May 27, 2005 Author Share Posted May 27, 2005 Cheers Nick Probably just needs a bit of getting used to. Have been clocking up the miles in the last couple of days, managed to get 21mpg on the first tank which was a plesant surprise. Still can't believe how quick it is! Didn't realise how much traction control holds it back, especially in first gear, but it certainly gets a lot twitchier with it off, especially when braking I've noticed... Anyway off for another drive Francis Link to comment Share on other sites More sharing options...
Robert Posted May 27, 2005 Share Posted May 27, 2005 glad to see another london driver on board hope to see you at the london meet mate,im amazed you can get into 6th in london though Link to comment Share on other sites More sharing options...
Chiefgroover Posted May 27, 2005 Share Posted May 27, 2005 I had this problem for a short while when i was using synthethic oil. A change to the toyota stuff and it went away? Weak pressure plate might do it too? p.s. 6th isnt directly behind 5th its slightly off line. Link to comment Share on other sites More sharing options...
francis Posted May 27, 2005 Author Share Posted May 27, 2005 Just went out for a quick spin, my fault, I had assumed it was all the way to the right and down but it's slightly to the left, no problems getting it in now Would love to come to the London meets, should be down Santa Pod next weekend too. Cheers, Francis Link to comment Share on other sites More sharing options...
Ian C Posted May 27, 2005 Share Posted May 27, 2005 You are probably catching the reverse gate, that's all -Ian PS better than catching the gate reversing har har Link to comment Share on other sites More sharing options...
Keith C Posted May 29, 2005 Share Posted May 29, 2005 Try checking that the leather gearstick boot isn't getting in the way - it can very easily prevent you getting into 5th/6th if it's not properly adjusted. Link to comment Share on other sites More sharing options...
scooby_doo_do Posted May 29, 2005 Share Posted May 29, 2005 I some times have trouble as well... But thats when i'm doing 120+... I have to wait for the car to slow down before i can engage it.... Only does it occasionally mind you.... Link to comment Share on other sites More sharing options...
