Guest Dimech90 Posted May 15, 2010 Share Posted May 15, 2010 Hi guys When i buy my supra, which engine is most prefered the late VVTi one or not? Are both the same in respects of tuning or is it slighly different due to the valve timing? Any pros or cons to the newer lump Cheers guys Arran Quote Link to comment Share on other sites More sharing options...
Rich8v Posted May 16, 2010 Share Posted May 16, 2010 It used to be said that the vvti engine had a lack of tunning options due to it being a newer engine. As opposed to the tried and tested non-vvti engine. But if you have a look around on this site there are several single turbo vvti engined cars putting out good power. SteveR comes to mind. Certanly if you were only going to bpu the car a vvti engine puts out more mid range torque. I sure some of the more experienced members will give some input in to this. Quote Link to comment Share on other sites More sharing options...
Wez Posted May 16, 2010 Share Posted May 16, 2010 I would say the VVTi is just as tunable as the non-VVTi but with the added bonus of variable cam setup, the DBW can be a pig to get right but even that has options now. Quote Link to comment Share on other sites More sharing options...
