Urgent help needed in norfolk!
dan1985
hi.
Very loud gurguling sound coming from under the bonnet when i accellerate. Think it could exturnal wastegate stuck open.
Dont know enough to have a proper look at it. Can someone come round and have a look.
Il pay you.
07501026238 as outside looking....
try a be a bit more descriptive a 'gurgling' sound would not make me think of the wastegate :blink: ?
Gurgling = fluid noise to me is that correct?
You could have a air lock in the coolant system? if its cold i'd check your rad level (should be to the brim) and then let her idle with the rad cap off (look for bubbles in the rad) and see if it gurgles with mild neutral reving (let it warm up a bit first).....pop the cap back on........turn the heater and blowers on and check for gurgling again and check you get hot air....................report back :)
could have loss of power but not sure. still goes when i press the go faster button. its mainly a sound thing. no leaks or anything like that. all pipes seem to be intact
You have a go faster button? :innocent:
my brother in law who is a mechanic just turned up and the first thing he said was blowing exhaust he then looked at exhaust manifold, there was a valve with a pipe coming off it with nothing on the end....?
That sounds like your waist gate mate.
ps im gutted by this
Dan I wish u were less hasty bud, I bet that was the first supra u actually went to see?
I hope u get it sorted, did u pay the full 7.5k for the car it sounds like a nightmare already mate, I wish u had waited untill Monday when my supra was back from shop, it's such a good reliable car.
Oh well you learn from your mistakes.
You paid 7.5k for a single?? At that price I would expect a few niggles
Hope you get it sorted soon
