supra steveo Posted May 15, 2010 Share Posted May 15, 2010 what size tyres do i need for a set on 10" rear tyres ? the fronts are 9"? Quote Link to comment Share on other sites More sharing options...
AndyT Posted May 15, 2010 Share Posted May 15, 2010 9.5" are 265. So 275 would be my two penneth. Quote Link to comment Share on other sites More sharing options...
jon5698 Posted May 15, 2010 Share Posted May 15, 2010 I think i have 285's on mine Quote Link to comment Share on other sites More sharing options...
jayssupra Posted May 15, 2010 Share Posted May 15, 2010 275-295 Quote Link to comment Share on other sites More sharing options...
Darragh Posted May 15, 2010 Share Posted May 15, 2010 My daddy has a gs 300 sport and it's running 275/35, the tyres look perfect not to big and not to small Quote Link to comment Share on other sites More sharing options...
Luxluc Posted May 15, 2010 Share Posted May 15, 2010 275-295 +1 Quote Link to comment Share on other sites More sharing options...
TTRickeh Posted May 15, 2010 Share Posted May 15, 2010 I'd go 275's. Quote Link to comment Share on other sites More sharing options...
aman00123 Posted May 15, 2010 Share Posted May 15, 2010 I'd go 285, just to be in the middle ;p Quote Link to comment Share on other sites More sharing options...
Nic Posted May 15, 2010 Share Posted May 15, 2010 Are they 18's? If so 18/30/275 or 18/30/285 Quote Link to comment Share on other sites More sharing options...
supra steveo Posted May 15, 2010 Author Share Posted May 15, 2010 yep they are 18s Quote Link to comment Share on other sites More sharing options...
TTRickeh Posted May 15, 2010 Share Posted May 15, 2010 Is that to keep the rolling radius close to stock Nic? I have 18/30/285 and wish I'd gone with a 35 profile for a bit more rubber. Quote Link to comment Share on other sites More sharing options...
jevansio Posted May 15, 2010 Share Posted May 15, 2010 285/30/18 or 295/30/18 Quote Link to comment Share on other sites More sharing options...
Nic Posted May 15, 2010 Share Posted May 15, 2010 (edited) Is that to keep the rolling radius close to stock Nic? I have 18/30/285 and wish I'd gone with a 35 profile for a bit more rubber. Yes closest to stock rolling radius. There's a useful tyre size calculator HERE which allows you to compare tyres sizes. Stock Tyres Sizes Front 16/50/225 Rear 16/50/245 Front 17/45/235 Rear 17/40/255 Edited May 15, 2010 by Nic (see edit history) Quote Link to comment Share on other sites More sharing options...
Kirk Posted May 15, 2010 Share Posted May 15, 2010 (edited) I manage a 255 on a 10" rear on 17s? 9.5" are 265. So 275 would be my two penneth. How you figure that when stock 17s are 9.5j and run a 255? Its all dependent on tyre choice, actual tyre sizes vary between brands. Pirelli p-zero rosso's are huge compared to falkens of the same size Edited May 15, 2010 by Kirk (see edit history) Quote Link to comment Share on other sites More sharing options...
supra steveo Posted May 30, 2010 Author Share Posted May 30, 2010 285/30/18 or 295/30/18 why a profile of 30 ? i was thinking of 235/40/18 for the fronts and 295/35/18 for the rears ??? Quote Link to comment Share on other sites More sharing options...
Scott Posted May 30, 2010 Share Posted May 30, 2010 The 35 is a %age bud, not a size. If you went with 35% of 295 you would get a 22" diameter including the tyre. The 30% profile would be closer to stock Quote Link to comment Share on other sites More sharing options...
Nic Posted May 30, 2010 Share Posted May 30, 2010 why a profile of 30 ? i was thinking of 235/40/18 for the fronts and 295/35/18 for the rears ??? Steve see tyre calculator link I posted above, if you put in the stock tyre size on one side you can then compare the new tyre size on the other, you want a 'Tyre rolling circumference' as close to stock setup as possible. Quote Link to comment Share on other sites More sharing options...
supra steveo Posted May 30, 2010 Author Share Posted May 30, 2010 ahh right i see Quote Link to comment Share on other sites More sharing options...
