David P Posted May 14, 2010 Share Posted May 14, 2010 Conlight Very rare item. Original OEM Supra option in perfect working order. Automatically turns on/off side and/or headlamps. Fully adjustable for light level to operate. On and offable and switchable between sides and/or headlamps. Complete with 'plug & play' loom. Connects between steering column and dash looms. Light sensor and control module fits on dash next to pillar. When used on car fitted with a turbo timer, lights turn off automatically when engine stops. Can also be wired to operate 'show lights'. A 10 minute fit, simply remove 2 x 10mm bolts on panel under steering column to access connectors. Best offer + £3 P&P. Will post first class to best offer received in open forum by 8pm monday. Link to comment Share on other sites More sharing options...
Guest ugp Posted May 14, 2010 Share Posted May 14, 2010 £5 Link to comment Share on other sites More sharing options...
RobD Posted May 14, 2010 Share Posted May 14, 2010 10 Link to comment Share on other sites More sharing options...
Swampy442 Posted May 14, 2010 Share Posted May 14, 2010 Dont Supras have auto lights? Well you live and learn GLWS Link to comment Share on other sites More sharing options...
ufop Posted May 14, 2010 Share Posted May 14, 2010 £10.50 Link to comment Share on other sites More sharing options...
Robzki Posted May 14, 2010 Share Posted May 14, 2010 15 Link to comment Share on other sites More sharing options...
Robzki Posted May 14, 2010 Share Posted May 14, 2010 out of interest was this oem supra from the factory? clever but looks aftermarket Link to comment Share on other sites More sharing options...
jackso11 Posted May 14, 2010 Share Posted May 14, 2010 so what exactly does this do? turns on the headlights when you get close? or with the interior light when the door unlocks? I don't understand :s Link to comment Share on other sites More sharing options...
danhicks22 Posted May 14, 2010 Share Posted May 14, 2010 From the description I'm guessing that it senses light levels and switches on side/head lights when it thinks you need them. Link to comment Share on other sites More sharing options...
mwilkinson Posted May 14, 2010 Share Posted May 14, 2010 £15.50 Link to comment Share on other sites More sharing options...
Robzki Posted May 14, 2010 Share Posted May 14, 2010 16 Link to comment Share on other sites More sharing options...
David P Posted May 14, 2010 Author Share Posted May 14, 2010 Below the translucent window on the top of the unit there is a sensor that registers ambient light level. Top left, there is a knurled wheel that adjusts the light level at which you want the lights to come on. At it's most sensitive setting it will even switch on the lights when passing under a bridge in broad daylight, then off again when you come out the other side. The switch on the r/h side is to select either side or headlamps, and the button on the top is the on/off selector. Once you have set it to your preference, if you have set it to headlamp mode, and leave switched on, you will never need to turn your lights on or off again. Link to comment Share on other sites More sharing options...
Swampy442 Posted May 14, 2010 Share Posted May 14, 2010 The same thing Soarers/Aristos have as stock, Im genuinely surprised. Did you remove this from your car? Link to comment Share on other sites More sharing options...
David P Posted May 14, 2010 Author Share Posted May 14, 2010 Yes, it was fitted to my Supra as an original Toyota option, along with folding wing mirrors and a black head lining. I removed it from my N/A Supra whilst fitting a TT dash loom to retrofit active spoiler and cruise ECU's. Keron tells me it is the only one he has ever seen that functions. Link to comment Share on other sites More sharing options...
aman00123 Posted May 15, 2010 Share Posted May 15, 2010 I have this on my supe too, it is nice to have, especially if you have TT with a turbo timer, acts as coming home lights (basically engine and lights will stay on until your in the house) ;p Link to comment Share on other sites More sharing options...
wile e coyote Posted May 15, 2010 Share Posted May 15, 2010 £17 mate Link to comment Share on other sites More sharing options...
mwilkinson Posted May 15, 2010 Share Posted May 15, 2010 £20 Link to comment Share on other sites More sharing options...
Wez Posted May 15, 2010 Share Posted May 15, 2010 Never heard of this as oem on a MKIV Link to comment Share on other sites More sharing options...
Robzki Posted May 15, 2010 Share Posted May 15, 2010 22 Link to comment Share on other sites More sharing options...
Guest ugp Posted May 15, 2010 Share Posted May 15, 2010 25 Link to comment Share on other sites More sharing options...
pistonbroke Posted May 15, 2010 Share Posted May 15, 2010 I've googled it, and can't find any info on it being OEM. Link to comment Share on other sites More sharing options...
Wyntersun Posted May 15, 2010 Share Posted May 15, 2010 On Toyodiy it has one for the Camry. http://www.toyodiy.com/parts/p_U_2000_TOYOTA_CAMRY_SXV20L-CEPNKA_8416.html?hl=89120 Link to comment Share on other sites More sharing options...
David P Posted May 15, 2010 Author Share Posted May 15, 2010 It is on page 2 of original Supra options brochure. Link to comment Share on other sites More sharing options...
themodifiedkid Posted May 15, 2010 Share Posted May 15, 2010 Ive got this on mine. I believe it was a facelift optional extra Link to comment Share on other sites More sharing options...
David P Posted May 15, 2010 Author Share Posted May 15, 2010 No names mentioned There is a lot of interest in this gizmo and I have received several 'private offers' by pm. The deal is 'what is say's on the tin'. I don't have a figure in mind, just put it up for grabs and a bit of weekend fun. However, I am not completely immune to bribery Currently I am searching for 3 Supra items; A cruise control stalk for a 3 spoke wheel. A headlamp adjust control switch. A drivers door knee pad. Should anyone come up with any of these items, they can be included in offer to negotiate a trade/bribe. Any coercion to be posted openly in this thread please. Link to comment Share on other sites More sharing options...
