hodge Posted May 14, 2010 Share Posted May 14, 2010 Hi guys. Im doing a bit of work on a car for a fellow member. its got an ABS and Trac fault. Ive checked the ABS fault codes as posted by Ian C, and got the following codes. ABS light gives code 11 Slip con Off light gives codes 51 and 52. Ive reset the codes but after 20 seconds or so of driving the come back again. Could someone please point me in the right direction to where to start with fixing the errors. Thanks John Link to comment Share on other sites More sharing options...
merckx Posted May 14, 2010 Share Posted May 14, 2010 (edited) I'm not sure if I follow what you're saying. Have you fixed the ABS and Trac? Fault codes won't go away permanently by just resetting if the components that aren't functioning correctly haven't been fixed or replaced etc. Edited May 14, 2010 by merckx (see edit history) Link to comment Share on other sites More sharing options...
hodge Posted May 14, 2010 Author Share Posted May 14, 2010 havnt fixed any of it that's why I'm asking for help. Link to comment Share on other sites More sharing options...
merckx Posted May 15, 2010 Share Posted May 15, 2010 Have a look in the diagnostics section, it's very good. http://www.turbosupras.com/pages/pages/technical/jza80/a80tsrm.htm Link to comment Share on other sites More sharing options...
