replacement key ,ask from germany
Guest erha
Guest erha
hello,
greetings from Germany, my name is erha and would like to know how his turn to the key-number to a replacement key to order from toyota. Just drive a supra tt 1998 with bpu Jap-spec manual gear, I apologize for my spell , am very grateful to you for your help...
Guest erha
hi stevie,
yes I have a remote key, I need only a second as a substitute. toyota dealer said that a five digit number on closed behind the paneling on the drivers side should be embossed, but I have 6-digit number ...
hi stevie,
I got my spare keys from Ebay and theyre very good too :)
Guest erha
but need a second replacement key with the chip (immobilizer), is the number I use for the order from toyota need for stamped behind the door paneling?:blink:
My keys don't have an immobilizer. The immobilizer function is performed by the key fob of my aftermarket alarm.
I'm assuming you have the standard Toyota alarm fitted. Is that correct? I don't know much about the standard alarm, so I can't help with that.
