help needed
fabiocandido
hello guys,
i fit a new radio, sub and amp,everything working fine for first couple of days and now when i turn on the lights the rear lights start flashing, and when the lights are off if i press the brake the instrument cluster lights come on. (i have the plasma glow dials).
i stripped the car this afternoon checked all wires, changed the ground ones and still problem continues.
any thoughts on this??
battery maybe?..
thanks
Sounds like you have managed to wire into 3 different looms?! You need to take the lot out one by one and find the problem, mark which wires you had connected to which with coloured pens and you should be able to eventually find the solution.
If this doesn't work, return it to standard and start again. If you can't return it to standard your a bit buggered.
I know it's a lot of work mate, but it will help
Gary
