Auto gear knob
Guest johnny boy
Guest johnny boy
hey guys my auto gear knob is looking a little worse for wear these days and wondered how easy is it to remove and if anyone knows where i can get another good one in black leather?
I got a new one from Toyota, about £27 I think. It's literally just the leather bit so you have to re-use the overdrive and lock switches. I managed to break the overdrive switch and had to fix it with a bit of circuit board I custom made, but if your not as clumsy as me it's quite straight forward to change the handle. Just the plastic ring bit at the bottom of the handle covering a screw is a bit difficult to get off without breaking it (I broke that as well).
Guest johnny boy
So how does it come off. i guess the ring around the bottom slides down but how do i get the plastic bit off the side and do i need to remove the overdrive button?:)
A nice fella called nOOb wrote this out for me. :)
its pretty tricky mate .... took me a while and lost some blood/tissue/sweat...
1... take off the dash surrounding the gear knob + ashtray etc
2 unscrew the 4 screw holding the gear lever assembly on
3 prize the black bit under the gear knob down gently to reveal two screws ... take them off
4 prize gently the black gear button bit (with the over drive button) off... it will hang by a wire
5 trace the blue wire down the gear lever then around the back of the gear lever then it goes into a blue Toyota connector.
6 try and undo this with out attacking it to much... i mad e a right mess of mine... when the blue wire are disconnected pull them back up around the gear box... remember it path...
7 pull the wires out of the gear knob and then feed back into your new gear knob ,,,
8 replace new gear knob on top of the lever trace the route back to the blue toyota connector ... reconnect it
9 screw everything back together
10 put dash back
11 done get a beer
its a bit of a bitch but well worth it
this instructions are not great but its how i did it
hope it helps
n00b
Good luck. :)
