EdMorris Posted June 13, 2010 Share Posted June 13, 2010 But now have to remove gearbox because I'm having issues with clutch adjustment Not you as well? Anything specific? Link to comment Share on other sites More sharing options...
Fearless Posted June 13, 2010 Share Posted June 13, 2010 Not you as well? Anything specific? Had the gearbox in and out twice today an and no amount of adjustment helps. There is not enough travel on the clutch slave cylinder to disengage the clutch unless the release bearing is already pressing on the pressure plate (obviously not a good idea as it will quickly destroy the bearing) However I had the same issues when I had this clutch with the 2jz I have come to the conclusion that I have to either get a slave cylinder with a slightly smaller internal diameter or a master cylinder with a slightly bigger diameter to give me another 5mm of travel. Link to comment Share on other sites More sharing options...
Guest SupraN Posted June 13, 2010 Share Posted June 13, 2010 Come on steve, get a little video up. PLEASE yes we all need to see video:d Link to comment Share on other sites More sharing options...
EdMorris Posted June 14, 2010 Share Posted June 14, 2010 Had the gearbox in and out twice today an and no amount of adjustment helps. There is not enough travel on the clutch slave cylinder to disengage the clutch unless the release bearing is already pressing on the pressure plate (obviously not a good idea as it will quickly destroy the bearing) However I had the same issues when I had this clutch with the 2jz I have come to the conclusion that I have to either get a slave cylinder with a slightly smaller internal diameter or a master cylinder with a slightly bigger diameter to give me another 5mm of travel. Right, I installed a 3/4" bore master cylinder in my setup, but the only one I could find with an offset flange mounting (similar to the OEM one) was a short body model from AP racing. I still don't have the travel I need and this MAY be due to the short body design. If you go down this route, you will need to adapt the mounting to fit and the master cylinder itself as it will, 1. not be the right mounting, 2. not have the right thread for the pedal clevis, and 3. you'll also most likely need a remote reservoir (depending on model and amount of clearance it gives you). I can't remember about the line threads, but this is easily solved with a new adapter. I looked at ALL manufacturers, and none had exactly the right spec, save for the AP racing one (and even then the mounting needed a plate to make it fit). I would try something else before you messed about with the OEM master as its a pain in the proverbial. Just a word of advice Link to comment Share on other sites More sharing options...
Nodalmighty Posted June 14, 2010 Share Posted June 14, 2010 I thought the day was quite fun. First time I've worked actually worked with Ryan, even though I've known him years. I'm watching this develop as it's very close to the engine spec going in my MR2 (all be it twin CT20b's) and want to know what I can expect. So glad I've gone the semi built Auto and paddle shift route Lyndon. Link to comment Share on other sites More sharing options...
Fearless Posted June 14, 2010 Share Posted June 14, 2010 Right, I installed a 3/4" bore master cylinder in my setup, but the only one I could find with an offset flange mounting (similar to the OEM one) was a short body model from AP racing. I still don't have the travel I need and this MAY be due to the short body design. If you go down this route, you will need to adapt the mounting to fit and the master cylinder itself as it will, 1. not be the right mounting, 2. not have the right thread for the pedal clevis, and 3. you'll also most likely need a remote reservoir (depending on model and amount of clearance it gives you). I can't remember about the line threads, but this is easily solved with a new adapter. I looked at ALL manufacturers, and none had exactly the right spec, save for the AP racing one (and even then the mounting needed a plate to make it fit). I would try something else before you messed about with the OEM master as its a pain in the proverbial. Just a word of advice I am just wondering is there is any difference between the n/a and tt clutch master/slave Link to comment Share on other sites More sharing options...
Fearless Posted June 14, 2010 Share Posted June 14, 2010 I thought the day was quite fun. First time I've worked actually worked with Ryan, even though I've known him years. I'm watching this develop as it's very close to the engine spec going in my MR2 (all be it twin CT20b's) and want to know what I can expect. So glad I've gone the semi built Auto and paddle shift route Lyndon. Big thanks to Lyndon and Ryan who battled away all day to get this running. My wish to change this from the OEM distributor and HT leads to individual coil packs gave you a both few extra headaches I'm sure but the 8 channel igniter you made is working great. The pair of you are sheer genius's I can't believe how responsive this is and how nice it feels to drive. Really looking forward to getting this fully mapped at SRR on the 25th Link to comment Share on other sites More sharing options...
EdMorris Posted June 14, 2010 Share Posted June 14, 2010 I am just wondering is there is any difference between the n/a and tt clutch master/slave I think there may be. I'm sure I saw a thread on this recently while I was browsing for inspiration. I'll have a quick check. Link to comment Share on other sites More sharing options...
EdMorris Posted June 14, 2010 Share Posted June 14, 2010 Here we go, have a look through this. http://www.mkivsupra.net/vbb/showthread.php?t=194804&highlight=master+cylinder Link to comment Share on other sites More sharing options...
edge Posted June 14, 2010 Share Posted June 14, 2010 I am just wondering is there is any difference between the n/a and tt clutch master/slave Steve there was talk about slave cylinders on here a few days back and i think the 6speed box from the later facelift n/a's have a different cylinder giving better disengagement. I will have a quick search for it. Link to comment Share on other sites More sharing options...
edge Posted June 14, 2010 Share Posted June 14, 2010 Have a read through this steve http://www.mkivsupra.net/vbb/showthread.php?t=194804&highlight=slave+cylinder Link to comment Share on other sites More sharing options...
Fearless Posted June 14, 2010 Share Posted June 14, 2010 Part number for the n/a 6 speed slave cylinder is 31470-14070. £58 from Steve Manley inc delivery. Sounds like this is what I need then ? I will order one tomorrow and let you know how I get on Link to comment Share on other sites More sharing options...
Fearless Posted June 16, 2010 Share Posted June 16, 2010 (edited) For those that have asked but please bear in mind this is not fully mapped yet vu2nVXMByXw And another q-nr1qbxHfU Edited June 16, 2010 by Fearless (see edit history) Link to comment Share on other sites More sharing options...
Supra N_A Posted June 16, 2010 Share Posted June 16, 2010 WOWW [sHOCK][/sHOCK] sounds bloody awesome that mate and looks like a very nice supra! what power is this kicking out? Link to comment Share on other sites More sharing options...
Blackie Posted June 16, 2010 Share Posted June 16, 2010 Amazing mate, Sounds fantastic Link to comment Share on other sites More sharing options...
leelbuk Posted June 16, 2010 Share Posted June 16, 2010 I WANT ONE /vbb/images/smilies/bbcode_shock.gif Glad you're local Steve so I get to see (and HEAR!) this more often!!! How much you charging for passenger rides then??? I call shotgun btw Link to comment Share on other sites More sharing options...
leelbuk Posted June 16, 2010 Share Posted June 16, 2010 I WANT ONE /vbb/images/smilies/bbcode_shock.gif I think congrats are in order - great to see how quickly you've pulled this off! Glad you're local Steve so I get to see (and HEAR!) this more often!!! Sounds the muts nuts! How much you charging for passenger rides then??? I call shotgun btw EDIT: sorry for the double post Link to comment Share on other sites More sharing options...
edinlexusV8 Posted June 16, 2010 Share Posted June 16, 2010 Big thanks to Lyndon and Ryan who battled away all day to get this running. My wish to change this from the OEM distributor and HT leads to individual coil packs gave you a both few extra headaches I'm sure but the 8 channel igniter you made is working great. The pair of you are sheer genius's I can't believe how responsive this is and how nice it feels to drive. Really looking forward to getting this fully mapped at SRR on the 25th Great project and well done!! I would like to know how you replaced the distributor with individual coil plugs? Do you have any pics? Cheers Link to comment Share on other sites More sharing options...
DodgyRog Posted June 16, 2010 Share Posted June 16, 2010 Got to love the sound of a V8. Another nice project coming out of the South West Link to comment Share on other sites More sharing options...
EdMorris Posted June 17, 2010 Share Posted June 17, 2010 Sounds very nice mate, top job. Thats the only kind of start I can do also P.S. you're bay still looks tidier than mine, ha ha. Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted June 17, 2010 Share Posted June 17, 2010 yeah agree the v8 sounds awesome pus the added whooosssh puts the cherry on top. how much has this build roughly set you back? Link to comment Share on other sites More sharing options...
edge Posted June 17, 2010 Share Posted June 17, 2010 Very nice steve. How did you get on with that slave cylinder? Link to comment Share on other sites More sharing options...
barneybrendan Posted June 17, 2010 Author Share Posted June 17, 2010 great to hear it running mate,cracking job Link to comment Share on other sites More sharing options...
Fearless Posted June 17, 2010 Share Posted June 17, 2010 WOWW [/sHOCK] sounds bloody awesome that mate and looks like a very nice supra! what power is this kicking out? Not sure yet as it is not fully mapped, has a map cut on it at 0.5bar but hoping for at least 600bhp on surry Rolling road next week. Amazing mate, Sounds fantastic Cheers, wait until you hear it up close [sHOCK]I WANT ONE /vbb/images/smilies/bbcode_shock.gif Glad you're local Steve so I get to see (and HEAR!) this more often!!! Sounds the muts nuts! I call shotgun btw Any time, after next Friday Great project and well done!! I would like to know how you replaced the distributor with individual coil plugs? Do you have any pics? Cheers I used my existing supra coil packs (I had 2 sets) and modified the extenders from nissan 300zx coil packs (a mate has quite a few of those) Then made up a holder for them with some folded aluminium sheet. I will try and get some picture up tomorrow Got to love the sound of a V8. Another nice project coming out of the South West Can't beat us SW boys Sounds very nice mate, top job. Thats the only kind of start I can do also P.S. you're bay still looks tidier than mine, ha ha. yeah agree the v8 sounds awesome pus the added whooosssh puts the cherry on top. how much has this build roughly set you back? About £4,000 but I already had a lot of bits as this was already a single turbo car and I got £2,500 back for parts from the 2jz that were not needed. BUT if you see my wife don't forget it only cost £3,000 and I got back £3,000 for parts I sold Very nice steve. How did you get on with that slave cylinder? Got it on order but it won't be here until 24th Link to comment Share on other sites More sharing options...
Fearless Posted June 17, 2010 Share Posted June 17, 2010 great to hear it running mate,cracking job Thanks for all your help Barney. Link to comment Share on other sites More sharing options...
