Track day tyre pressure?
Ganty
It's the hot ressure you're interested in, so blast it round a few laps and see what happens. If the pressures go up a lot, drop them to what you normally use on the road and use that as a default starting place.
Be careful though, if you drop the pressures then obviously when you stop driving the pressure wil drop much further and will handle badly until you get the heat, and thus pressure, back up again. That could take a few laps, depending on how hard you are able to drive the car.
Thanks Steve
will try stock pressure first then and see how it goes!
As a ball park figure, 32 PSI cold, 38 hot, set a sensible cold pressure, do a few laps (say 5 at a proper speed), and reset. Without proper tyre probe measurements it will only ever be a good guess. My main concern at Japfest would be keeping out of the way of the nutters, not tyre pressures, plus you are unlikely to get the tyres warm anyway.
lol yes I will be keeping well back from some of the numptys! Thanks for that chris;)
