jackso11 Posted May 12, 2010 Share Posted May 12, 2010 or something similar to secure them? When changing tired old rubber hoses to shiney black silicone ones, if they don't have anything securing them before will they need a cable tie or anything? Quote Link to comment Share on other sites More sharing options...
michael Posted May 12, 2010 Share Posted May 12, 2010 Yes, unless you want them to come off of course. Quote Link to comment Share on other sites More sharing options...
jackso11 Posted May 12, 2010 Author Share Posted May 12, 2010 so why do the original rubber hoses not have any kid of tieor thing securing them? Quote Link to comment Share on other sites More sharing options...
mwilkinson Posted May 12, 2010 Share Posted May 12, 2010 I have cable tied mine. Peace of mind if nothing else. Quote Link to comment Share on other sites More sharing options...
michael Posted May 12, 2010 Share Posted May 12, 2010 so why do the original rubber hoses not have any kid of tieor thing securing them? Because they are made from a material that doesn't require such things unless it's under pressure. Quote Link to comment Share on other sites More sharing options...
mwilkinson Posted May 12, 2010 Share Posted May 12, 2010 Stock hoses tend to have thicker supported walls which hold the pipe in place. Most aftermarket hoses are quite slippery and lack any form of internal supporting structure. Edit - I'm always too slow to respond. Quote Link to comment Share on other sites More sharing options...
jackso11 Posted May 12, 2010 Author Share Posted May 12, 2010 Yeah I thought that might be the case but wanted to ask to make sure. I emailed samco to get some 4mm and 5mm hose with fabric supported walls but they said not on a pipe that small. Better get some cable ties then. Quote Link to comment Share on other sites More sharing options...
Guest sparkso Posted May 12, 2010 Share Posted May 12, 2010 generally you dont need them on vac hoses, but i would always put one on just to be sure Quote Link to comment Share on other sites More sharing options...
Scott Posted May 12, 2010 Share Posted May 12, 2010 Lots of the hoses have the little spring clips on them to hold them in place? Don't you still have them? Quote Link to comment Share on other sites More sharing options...
Mcgoo Posted May 12, 2010 Share Posted May 12, 2010 so why do the original rubber hoses not have any kid of tieor thing securing them? I thought they came with spring clips on them from the factory. Quote Link to comment Share on other sites More sharing options...
Scott Posted May 12, 2010 Share Posted May 12, 2010 Ed was right, it is getting empty in here, I can hear an echo Quote Link to comment Share on other sites More sharing options...
Terminator Posted May 12, 2010 Share Posted May 12, 2010 It really depends on the interior diameter of the hose and the exterior diameter of the barb you are putting them on. All my small bore silicone hoses are pushed on and have no ties, they were all a pig to get on, and very hard to get off. If they slip on easily you will need to clamp them in some way. Quote Link to comment Share on other sites More sharing options...
jackso11 Posted May 13, 2010 Author Share Posted May 13, 2010 I still have all the original clips, haven't changed any hoses yet. Apart from my BOV rubber hose to a new rubber hose as the last one had a hole in it and had morphed into hard plastic. Magic Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted May 13, 2010 Share Posted May 13, 2010 I have never bothered with any form of clamps with silicone hoses, never had any come off, once fitted they tend to be hard to just pull off. Quote Link to comment Share on other sites More sharing options...
