Guest van_damme_supra Posted May 12, 2010 Share Posted May 12, 2010 hi, i was getting my dials out to fit my el-glo's and i saw this box attached to my speedo.. is it a speedo converter and does it meen if i don't put it back my speedo will be showing km/u? i know it sounds pretty stupid but i bought the car here in belgium and i don't know if it's in km or miles.. Quote Link to comment Share on other sites More sharing options...
stevie_b Posted May 12, 2010 Share Posted May 12, 2010 It looks very much like a speedo converter. With it, your car almost certainly reads in mph. Without it, it'll read in kph. You'd need to re-attach the speed signal wires though, basically returning the wiring to standard. I can post up a wiring guide for a DSC if you want, then you may be able to reverse-engineer it. Quote Link to comment Share on other sites More sharing options...
Guest van_damme_supra Posted May 12, 2010 Share Posted May 12, 2010 It looks very much like a speedo converter. With it, your car almost certainly reads in mph. Without it, it'll read in kph. You'd need to re-attach the speed signal wires though, basically returning the wiring to standard. I can post up a wiring guide for a DSC if you want, then you may be able to reverse-engineer it. that would be great i have another question. i'm not able to solder my wires for my el-glo's to work. i was thinking the following: my ugly green bulbs are out so what if i take the bulbs out of the holders, put the holders back with the wires between it. would that work? i just don't know where to put - and +.. [OOPS][/OOPS] Quote Link to comment Share on other sites More sharing options...
Guest van_damme_supra Posted May 12, 2010 Share Posted May 12, 2010 wait a minute, i think the el-glo's i bought in km/u are ment to be used an mph reader.. so if i would reverse-engineer it, i'd be messing it up.. i'll check first Quote Link to comment Share on other sites More sharing options...
Shane Posted May 12, 2010 Share Posted May 12, 2010 http://www.mkivsupra.net/vbb/showthread.php?p=1875514#post1875514 This thread will show you where to find + and - on the dash lights. Quote Link to comment Share on other sites More sharing options...
stevie_b Posted May 12, 2010 Share Posted May 12, 2010 I'm not familiar with the El-Glo so I can't advise on that. A schematic for wiring up a DSC is here: http://homepage.ntlworld.com/peter.betts/supra/TechTips/dsc_speedo_mph.jpg Quote Link to comment Share on other sites More sharing options...
Guest van_damme_supra Posted May 12, 2010 Share Posted May 12, 2010 yep, just checked it and when i put the kmh on the mph the 140 is on the 225 so problem solved, i don't have to do anything Quote Link to comment Share on other sites More sharing options...
Guest van_damme_supra Posted May 12, 2010 Share Posted May 12, 2010 thanks man Quote Link to comment Share on other sites More sharing options...
