Space saver spare wheel queries...?
Brazil
Hi guys,
Does anybody know if I have 19'' wheels and the car is lowered will I be able to use the space saver spare wheel...? I have a can of that flat repair any way so I was thinking of taking it out of the car..!
Would taking the wheel out mess with the car's geo...?
Thank's in advance...!:p
The size of your wheels should make no difference if you have the correct tyres fitted, the rolling radius of the wheels/tyres should be the same as if you had stock wheels fitted.
Removing the wheel will has no effect on the cars geometry, just means a little less weight over the rear wheels.
Ahhh bigger wheels thinner tires, smaller wheel bigger tires..!
Ps. I found an old thread when I was looking for info on changing the cam belt and found one that you wrote giving the link to your website which has Toyota manual in English, but it requires a password...?
I did find a Toyota servicing recommendation and did not see any thing about changing the fuel filter...? I have 60k miles would it not be a good idea to change it out...?
Thanks' Nic for ur help...! ;)
