another clutch to 2jzgte engine
supra mkiv
some who knows about you can get made a cintermetal clutch which correspond to a std clutch. run with a 3 fodet now have heard the more feet the better start. want one which has a start-up as a std clutch, then will probably say so buy a std clutch, but it is not possible, partly because they are not to find and partly due to my current flywheel and presser foot adapted my cintermetal clutch and hence can not simply just put std clutch plate along with my current presser foot and flywheel
what?
do you want a triple plate clutch?
I run with a zindermetal clutch, and it shakes the entire driveline when starting, so would like to hear about other experiences with other zindermetal coupling with more foot plates on the clutch plate ..
I do not know, accurate what I want. just want to hear if there are others who run zintermetal coupling. and whether they can do a soft launch as a std clutch does.
Edited by supra mkiv (see edit history)
