supra mkiv Posted May 11, 2010 Share Posted May 11, 2010 some who knows about you can get made a cintermetal clutch which correspond to a std clutch. run with a 3 fodet now have heard the more feet the better start. want one which has a start-up as a std clutch, then will probably say so buy a std clutch, but it is not possible, partly because they are not to find and partly due to my current flywheel and presser foot adapted my cintermetal clutch and hence can not simply just put std clutch plate along with my current presser foot and flywheel Quote Link to comment Share on other sites More sharing options...
dcarrter21 Posted May 11, 2010 Share Posted May 11, 2010 what? do you want a triple plate clutch? Quote Link to comment Share on other sites More sharing options...
supra mkiv Posted May 11, 2010 Author Share Posted May 11, 2010 (edited) what? do you want a triple plate clutch? I run with a zindermetal clutch, and it shakes the entire driveline when starting, so would like to hear about other experiences with other zindermetal coupling with more foot plates on the clutch plate .. I do not know, accurate what I want. just want to hear if there are others who run zintermetal coupling. and whether they can do a soft launch as a std clutch does. Edited May 11, 2010 by supra mkiv (see edit history) Quote Link to comment Share on other sites More sharing options...
dcarrter21 Posted May 12, 2010 Share Posted May 12, 2010 i run a 4 puk clutch with standard flywheel and it judders when i pull away slowly. just the way it is! Quote Link to comment Share on other sites More sharing options...
richarde7927 Posted May 12, 2010 Share Posted May 12, 2010 I have just fitted a 6 puk clutch with standard flywheel and that also judders on a slow pull away , i had the same type of clutch in my civic turbo as well and that was the same , it is just the way they are , Rich. Quote Link to comment Share on other sites More sharing options...
