Jamesy Posted May 10, 2010 Share Posted May 10, 2010 Hi guys just got couple of quick questions re the a/r housing on a turbo: 1. If a turbo has blown (bearings collapsed) will the exhaust housing still be ok to use on a different turbo? 2. Is the a/r housing size just written on the air filter side of the turbo right? 3. And is the exhaust housing part just the outside bit, that has four holes to bolt it to the manifold? Thanx in advance Quote Link to comment Share on other sites More sharing options...
CarlT67 Posted May 10, 2010 Share Posted May 10, 2010 I can answer question 2 for you, on my Precision turbo the a/r is written on the exhaust housing. Quote Link to comment Share on other sites More sharing options...
hodge Posted May 11, 2010 Share Posted May 11, 2010 1). Yes if the bearings are blown the turbine homusing should be ok. 2). The a/r should be wrote on the turbine housing (exhaust housing somewhere) but odviously models vary. 3). Yes the exhaust housing (turbine housing) is the outside bit, it's cast and bolts to the manifold and to the downpipe. The core goes inside with the compressor housing on the front. Quote Link to comment Share on other sites More sharing options...
Jamesy Posted May 11, 2010 Author Share Posted May 11, 2010 Thanx a lot John Quote Link to comment Share on other sites More sharing options...
