manual engine into an auto car
mobsta_01
Not sure the NA autobox will handle the torque, also there is some wiring differences between the NA and TT autobox and not the sort that can be gotten around too easily.
You would need the torque convertor and flex plate, but mechanically it shouldn't be a difficult job.
What if i get a tt auto box too? Will i need a different loom ecu or anything?
If you get an auto TT box, loom and ECU then it should be a fairly straight forward install, and I would DEFINITELY suggest that route.
I was thinking of buying the engine Nicolai has for sale or there's another one that i got offered too. Aparently it's everything i need for a na-tt conversion. But it's from a tt 6 speed.
I'm pretty sure if you have a good tt6 loom, someone doing a auto/manual conversion the other way would swap.
Suggest? :innocent: Require is more like it :D I know you were understanting it though ;)
TT looms seem to be incredibly difficult to source and do not count on the breakers to be able to supply one. The auto looms work on the 6spd but not vice versa so are in very short supply.
If possible try and get a package, it will be a real pain to patch a TT auto into an NA auto without everything included in one go. They can be retro-wired but you need to really know your way round the loom wiring and Toyota docs to do that.
I wouldn't be doing any of the work my self. Was hopeing to get one of the traders on here to do it.
The engine that Nicolai is selling doesn't have a loom. But the other one has a full loom and ecu etc. Here is a list of everything that he's going to give me:
:Complete Block Head
6-Speed Getrag gearbox
Clutch Fly wheel assembly
6-Speed Rear Differential with Axel's
ECU
Uncut wiring harness
Igniter chip
Sensors
Twin turbo
Exhaust manifold
Down pipe
Intake manifold
Injectors
Alternator
Starter
Power steering pump
A/C compressor
If you get a manual engine and want to run it with an auto box you MUST take out the spigot bearing in the back of the crankshaft before trying to mate it to the auto box!!
He will love trying that!!!!!:search: Should we tell him the little 'trick' for getting them out???:innocent:
  • 3 weeks later...
I've got everything i need for my na-tt conversion now.
Just can't get a hold of an auto tt ecu and loom. :(
A few folks said they might swap theirs.
Anyone got one?
I'm willing to give them a manual ecu and loom in return.
